Hi I want to get a set of steel rims for my 09 Vibe for 16" snow tires. The problem is i cant afford TPMS wheels or sensors so i want to get them installed on regular rims.What bolt pattern do i need? What older cars without TPMS use the sanme wheel? is this the same as older Vibes? or Corolas?Thanks
Quote, originally posted by scrappie »Hi I want to get a set of steel rims for my 09 Vibe for 16" snow tires. The problem is i cant afford TPMS wheels or sensors so i want to get them installed on regular rims.What bolt pattern do i need? What older cars without TPMS use the sanme wheel? is this the same as older Vibes? or Corolas?Thankswhich vibe? base, gt or awd?if you have the base you need 5x100 bolt patternif you have the gt or awd you need 5x114 bolt patternThe old set of steelies from a vibe, matrix, corolla, celica will work on the base vibe only not on the gt or awd
What engine do you have? If you have the 1.8L Engine, you have a 5x100 bolt pattern. If you are looking for am extra set of steel rims, I have a set available.
Everyone seems to be asking this very same question. Does anyone know what the offsets are for the second gen Vibe 1.8L and 2.4L engined cars. Are they the same as the 03-08s??????
