Will old Steel rims fit 09 Vibe?
scrappie
Post by scrappie »
Hi I want to get a set of steel rims for my 09 Vibe for 16" snow tires. The problem is i cant afford TPMS wheels or sensors so i want to get them installed on regular rims.What bolt pattern do i need? What older cars without TPMS use the sanme wheel? is this the same as older Vibes? or Corolas?Thanks
keithvibe
Re: Will old Steel rims fit 09 Vibe? (scrappie)
Post by keithvibe »
Quote, originally posted by scrappie »Hi I want to get a set of steel rims for my 09 Vibe for 16" snow tires. The problem is i cant afford TPMS wheels or sensors so i want to get them installed on regular rims.What bolt pattern do i need? What older cars without TPMS use the sanme wheel? is this the same as older Vibes? or Corolas?Thankswhich vibe? base, gt or awd?if you have the base you need 5x100 bolt patternif you have the gt or awd you need 5x114 bolt patternThe old set of steelies from a vibe, matrix, corolla, celica will work on the base vibe only not on the gt or awd
scrappie
Re: Will old Steel rims fit 09 Vibe? (keithvibe)
Post by scrappie »
Its a base Vibe with OEM steels
scrappie
Post by scrappie »
So any age Vibe, Matrix or Corolla will fit? or only recent?Thanks for the info
keithvibe
Re: (scrappie)
Post by keithvibe »
03-08 will fit
ou.grizzly
Post by ou.grizzly »
What engine do you have? If you have the 1.8L Engine, you have a 5x100 bolt pattern. If you are looking for am extra set of steel rims, I have a set available.
scrappie
Post by scrappie »
Do i have to worry about offset? what is it, and has it changed recently? its the 1.8 base with auto in mystic blue, i love it!
vibolista
Re: (scrappie)
Post by vibolista »
Everyone seems to be asking this very same question. Does anyone know what the offsets are for the second gen Vibe 1.8L and 2.4L engined cars. Are they the same as the 03-08s??????
