03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
They should fit. Body wrinkles are different but the basic angles should match... especially the A-pillar. The windshield and the side door windows should be identical. I can' see GM/Toyota not sharing such a basic part.
Quote, originally posted by vibolista »They should fit. Body wrinkles are different but the basic angles should match... especially the A-pillar. The windshield and the side door windows should be identical. I can' see GM/Toyota not sharing such a basic part. I think the mirrors are the same, but you would be surprised! The Cabin Air Filter for the Matrix/Vibe are different.
that website shows that the mirriors are the same well atleast part numbers are the same. you would be amazed as to what manufaactues will do. on most to all older chevy trucks parts are all interchangable, and most parts are the same, from like 75 to 87 then some dodge parts wil lwork to chevy and some will work to dodge, this is limited more to the axle and suspension parts.
