Will Matrix mirrors fit?
DrunkenMonster
Post by DrunkenMonster »
2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote StartK&N Panel Air Filter, Removed Silencer, TB Coolant Bypass1998 Jeep Cherokee UKFlowmaster Super 44Cobra 25 LTD CB 2 JL Audio 10W0's / TMA 500
lovemyraffe
Re: Will Matrix mirrors fit? (DrunkenDixie)
Post by lovemyraffe »
Good question. Most body parts (sheet metal, headlights, taillights) are not interchangeable.
L5K
Post by L5K »
Looking for pictures of both cars' mirrors brought up this place that sells replacements. They list them as being the same. I guess they are? http://www.atozautolights.com/....html http://www.atozautolights.com/....html
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
vibolista
Re: Will Matrix mirrors fit? (L5K)
Post by vibolista »
They should fit. Body wrinkles are different but the basic angles should match... especially the A-pillar. The windshield and the side door windows should be identical. I can' see GM/Toyota not sharing such a basic part.
ou.grizzly
Re: Will Matrix mirrors fit? (vibolista)
Post by ou.grizzly »
Quote, originally posted by vibolista »They should fit. Body wrinkles are different but the basic angles should match... especially the A-pillar. The windshield and the side door windows should be identical. I can' see GM/Toyota not sharing such a basic part. I think the mirrors are the same, but you would be surprised! The Cabin Air Filter for the Matrix/Vibe are different.
crazyviber
Post by crazyviber »
that website shows that the mirriors are the same well atleast part numbers are the same. you would be amazed as to what manufaactues will do. on most to all older chevy trucks parts are all interchangable, and most parts are the same, from like 75 to 87 then some dodge parts wil lwork to chevy and some will work to dodge, this is limited more to the axle and suspension parts.
houseofbugs
Post by houseofbugs »
I just checked. The 03-07 Vibe and Matrix both take the same mirrors/
DrunkenMonster
Awesome thank you very much.
houseofbugs
I just ordered some aftermarket ones form ebay. Ill let you know how they work out.
