I have a 06 base and upon switching to full synthetic and installing a K&N air filter, I notice it runs a lot smoother. I've been using strictly 87 but I'd bet 89 would make a positive difference.
Both mine and my mom's '09 GTs get nothing but 89. It's the lowest octane at the Citgo station we go to, but it's mid grade everywhere else so it's a good deal.
87 octane unless the petrol station has 89 octane for the same price. This goes for the 1.8L in the 04 and 08; also for both 09s that have the 2.4L (same engine as the Vibe GTs)
Quote, originally posted by midnighthunder89 »why do you want to run e85?E85 has an octane rating of about 110 I believe, about the same as propane. So you can run with a 15:1 compression ratio without the costs of running race gas and while getting normal mileage.
I disagree with the mileage. When I have used E85 the mileage decreased greatly. I don't think it is worth it. It was just a Temp solution for people that were complaining that gas prices were too high. There is no way that it should be continued to be produced.... I can think of much more energy efficient solutions besides e85
yes the oct is higher. yes you use 30% more, but it is cheaper per gallon than 91 so it comes out about the same cost. Due to running boost the 91 is not good for my car so i have to add booster.
Quote, originally posted by midnighthunder89 »I disagree with the mileage. When I have used E85 the mileage decreased greatly. But is your car boosted, have you shaved the cylinder head? Regular engines waste the octane from E85, just like running supreme.http://www.raceone85.com/ (there are hunderds of sites like this)
