oil weight 1.9L vs 2.4 L
bikeman1
Post by bikeman1 »
Hi gang. Just changed my oil for the first time on my 2009 2.4L. Was surprised to see that 5W20 is the recommended weight. Truthfully, I always wondered how 5W30 was thick enough for the old 1.9L. how do engine designers set up the clearances to work with thinner oils? I understand why thinner oils are "greener" and appreciate that, but do we sacrifice bearing wear and engine life in the long haul?Any lube geeks out there....
Gamma Vibe ==> 2007 Base 5-speed, Neptune
Delta Vibe ==> 2009 Base 2.4L 5-speed, Red Hot Metallic
but still more bikes than Vibes....
Re: oil weight 1.9L vs 2.4 L (bikeman1)
http://www.bobistheoilguy.com/This site will answer all of your questions then give you tons more. Every possible opinion on any oil product!And the 5w20 works great!
Old Tele man
Post by Old Tele man »
...per the Owners Manual we're running 5W20 (synthetic) in our 2009 Vibe Base 1.8L.
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
And if you find yourself with an hour of nothing planned, give this a read. http://www.supramania.com/aehaas/ start at 101 and work your way down.
bikeman1
Re: oil weight 1.9L vs 2.4 L (star_deceiver)
Post by bikeman1 »
Quote, originally posted by star_deceiver »http://www.bobistheoilguy.com/This site will answer all of your questions then give you tons more. Every possible opinion on any oil product!And the 5w20 works great!wow -- everything you always wanted to know about oil but were afraid to ask! Thanks D.C.
