Hi gang. Just changed my oil for the first time on my 2009 2.4L. Was surprised to see that 5W20 is the recommended weight. Truthfully, I always wondered how 5W30 was thick enough for the old 1.9L. how do engine designers set up the clearances to work with thinner oils? I understand why thinner oils are "greener" and appreciate that, but do we sacrifice bearing wear and engine life in the long haul?Any lube geeks out there....
Gamma Vibe ==> 2007 Base 5-speed, Neptune
Delta Vibe ==> 2009 Base 2.4L 5-speed, Red Hot Metallic
but still more bikes than Vibes....
http://www.bobistheoilguy.com/This site will answer all of your questions then give you tons more. Every possible opinion on any oil product!And the 5w20 works great!
Quote, originally posted by star_deceiver »http://www.bobistheoilguy.com/This site will answer all of your questions then give you tons more. Every possible opinion on any oil product!And the 5w20 works great!wow -- everything you always wanted to know about oil but were afraid to ask! Thanks D.C.
