I've never had this problem, but my guess is that there's something wedged in the mechanism, or it's just gummed up. I'd say just unbolt the seat, pull it out, and take a look.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
Neither the driver's seat or the passenger's seat latch at the same time on mine... I always have to scoot back and forth to make sure it latched on both sides..
Are you the original owner?I thought I'd mention that after I was rear ended, my seat tracks were damaged and had to be replaced. If you bought your Vibe used, it might have been in and accident before
mine is a 09 vibe.. original owner.no accident no bump no scuff. It might be the seat frame itself is made from thin galvanized steel. Sort of like the same material you would see from a chocolate tin cans. These material are thin and easy to stamp and those are part of the cost cutting initiative to save cost and weight. Cars in pre 2000 era have sturdier seat frame than the newer ones. It looks like it is a general problem for vibe that both seat tracks cannot to anchor the same time unless you yank the seat .
