Driver seat track latching
cq358
Post by cq358 »
Does anybody have problem for the driver seat (front and back adjustment) latch is only catching one side instead of both side?
L5K
Re: Driver seat track latching (cq358)
Post by L5K »
I've never had this problem, but my guess is that there's something wedged in the mechanism, or it's just gummed up. I'd say just unbolt the seat, pull it out, and take a look.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
cq358
Re: Driver seat track latching (L5K)
Post by cq358 »
Both left and right craw never latch in the same time.. i need to yank the seat to make sure both tracks are latched in the correct position.
09vGT
Post by 09vGT »
Neither the driver's seat or the passenger's seat latch at the same time on mine... I always have to scoot back and forth to make sure it latched on both sides..
Re: (09vGT)
Rock'er back and forth. If that doesn't work, a few quick accelerations and hard brakings will latch it for you!
B14CK_H4WK
Post by B14CK_H4WK »
that sounds very dangerous if you ever got in an accident. ever try wd40? also is there any rust under the seats at all?
Herb
Post by Herb »
Are you the original owner?I thought I'd mention that after I was rear ended, my seat tracks were damaged and had to be replaced. If you bought your Vibe used, it might have been in and accident before
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
cq358
Re: Driver seat track latching (Herb)
Post by cq358 »
mine is a 09 vibe.. original owner.no accident no bump no scuff. It might be the seat frame itself is made from thin galvanized steel. Sort of like the same material you would see from a chocolate tin cans. These material are thin and easy to stamp and those are part of the cost cutting initiative to save cost and weight. Cars in pre 2000 era have sturdier seat frame than the newer ones. It looks like it is a general problem for vibe that both seat tracks cannot to anchor the same time unless you yank the seat .
