Which plug is the oil pan plug?
rollin
Post by rollin »
I see two different drain plugs, is the oil drain plug on the left side, or the one in the middle of the car? I would think it is the plug on the same side as the oil filter, correct????
keithvibe
Re: Which plug is the oil pan plug? (rollin)
Post by keithvibe »
for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.
rollin
Re: Which plug is the oil pan plug? (keithvibe)
Post by rollin »
it's an 04. And I thought it was the one on the passenger side...
tribalman
Post by tribalman »
from memory, it should be in the middle. right inline with the filter.
None. Vibe is gone.
zionzr2
Post by zionzr2 »
Quote, originally posted by keithvibe »for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.+1
hbutko
Post by hbutko »
Yes its the plug nearest the passenger side. Your oil pan is shaped like a T. the oil plug has a 14mm head.
Digger
Re: Which plug is the oil pan plug? (hbutko)
Post by Digger »
And think, I have been useing a 9/16 for 4 years now. never thought it was metric.
keithvibe
Re: Which plug is the oil pan plug? (Digger)
Post by keithvibe »
Quote, originally posted by Digger »And think, I have been useing a 9/16 for 4 years now. never thought it was metric. HAHAthe trans plug is a 10mm allen just in case people wanted to know
wyatt89
Post by wyatt89 »
Quote, originally posted by keithvibe »HAHAthe trans plug is a 10mm allen just in case people wanted to knowThat's bizarre, most cars have a 1/2" square hole so you can just stick a breaker bar in there if it's tough to get out It's quite nice.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
