I see two different drain plugs, is the oil drain plug on the left side, or the one in the middle of the car? I would think it is the plug on the same side as the oil filter, correct????
for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.
Quote, originally posted by keithvibe »for what year?but it's the one closer to the passenger side, on the engine.. not the transmission. The transmission pan is flat on the bottom. Then engine pan is black.+1
Quote, originally posted by Digger »And think, I have been useing a 9/16 for 4 years now. never thought it was metric. HAHAthe trans plug is a 10mm allen just in case people wanted to know
Quote, originally posted by keithvibe »HAHAthe trans plug is a 10mm allen just in case people wanted to knowThat's bizarre, most cars have a 1/2" square hole so you can just stick a breaker bar in there if it's tough to get out It's quite nice.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
