I've seen a few sets of stock Gen Coupe wheels for cheap on ebay lately and it's got me thinking. I'm in need of tires and I hate the stock wheels and offsets. I've searched the Genesis forums and I couldn't find what the stock offset is so I was curious if anyone has tried fitting them.I've been wanting something a little taller anyway.
Quote, originally posted by lovemyraffe »Those wheels will not fit. All the info I have found on them say the bolt pattern is 5x114.3. The Vibe's bolt pattern is 5x100.if he has the 2.4 2009 -- he's good to go
Quote, originally posted by bull77 »if he has the 2.4 2009 -- he's good to gothat might not be 100% true. Even though the bolt pattern is the same with the offset of the Genesis wheels will probably push the wheel to far out on a Vibe and maybe clearance issue with the fender lip. Plus the center bore is much bigger on the Genesis so the wheels will be nowhere near hubcentric on a Vibe either. Will need a test fit and a need to machine a custom centering ring before you can say good to go.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
