Growling & vibration - Puzzling (Edit: FIxed)
Ro04Vibe
Post by Ro04Vibe »
04 Vibe with 51000kms, auto. Runs very well with no codes, except that a bad growling/vibration has appeared only at idle when almost or completely stopped, in drive. Doesn't do it in neutral or reverse, or when at speed. I think it's a heat shield because of the intermittent clanging and squeaking near the firewall, but growling and solid vibration through the floorboard is something I've never experienced from just a loose shield... Any ideas? It appeared after I took the car for a test run on new wheels, and I stretched it's legs rpm-wise, something that never happens otherwise (wife's car)
04 Vibe - Red, All Stock
Ro04Vibe
Re: Growling & vibration - Puzzling (Ro04Vibe)
Post by Ro04Vibe »
Went under and found one part of the catalytic converter heat shield that was part of the convertor got loose and wedged itself between the convertor and the sway bar...
northvibe
Post by northvibe »
whoa good thing you checkeD!
Ro04Vibe
Re: (northvibe)
Post by Ro04Vibe »
Quote, originally posted by northvibe »whoa good thing you checkeD!Yeah, and it was a heavy gauge piece of steel, that's why it was transferring so much vibration and sound...
