new brakes = new noise!!
jerryjoe28
Post by jerryjoe28 »
ok guys help me out here. just did a brake job on my wifes car. got the rotors turned and new crem pads. at first every thing was fine but now. bout 2 weeks later. ive got this crazy noise when i come to a stop. it not your average brake noise. its no a constant noise its kinda a whamp. whamp . whamp and i cant figure it out. any ideas?
keithvibe
Re: new brakes = new noise!! (jerryjoe28)
Post by keithvibe »
first thing i would do is check your lug nuts. Could be loose. Then check the caliper bolts.
kostby
Post by kostby »
I had the brakes on my 2003 done by my local dealer two summers ago and had the same kind of thing happen. There was absolutely no effect on braking performance, only a lot of scary noises under braking.I thought it was that maybe they used the wrong pads, or failed to install them properly (shims, perhaps?), but the after letting the 'Service Writer' (using the term loosely) drive the car and keep it for a day, he said that the rotors were somehow turned out-of-round, the dealership bought me new rotors. Problem solved, and it hasn't returned.
ehoff121
Post by ehoff121 »
Improper lug nut torque can cause this. http://forums.genvibe.com/zero...54410
jerryjoe28
ok ill check the lug nuts but after driving it tonight with the windows down i noticed. the loud whamp whamp noise stops when you let of the pedal but for a lil bit ther is still a slight "grinding squeal" in the same noise pattern for a lil while after you start moving agian
jerryjoe28
ok guys i checked the bolts there all tight. any other ideas?
bull77
Re: (kostby)
Post by bull77 »
have you gone back to the dealer to check on the rotors?Quote, originally posted by kostby »I had the brakes on my 2003 done by my local dealer two summers ago and had the same kind of thing happen. There was absolutely no effect on braking performance, only a lot of scary noises under braking.I thought it was that maybe they used the wrong pads, or failed to install them properly (shims, perhaps?), but the after letting the 'Service Writer' (using the term loosely) drive the car and keep it for a day, he said that the rotors were somehow turned out-of-round, the dealership bought me new rotors. Problem solved, and it hasn't returned.
jerryjoe28
pulling everything back apart this weekend. i'll run the rotors back n have them cecked. im gona pull every thing apart and clean it all then lube the slides anyone have any sug. on anything special i should do. (what all should i lube and what lubes should i use?)
bull77
Re: (jerryjoe28)
Post by bull77 »
ehoff121
Re: (jerryjoe28)
Post by ehoff121 »
Quote, originally posted by jerryjoe28 »ok guys i checked the bolts there all tight. any other ideas?Did you check with a torque wrench? Being too tight is the potential issue.
THE VIBERATOR
Re: (ehoff121)
Post by THE VIBERATOR »
Quote, originally posted by ehoff121 »Did you check with a torque wrench? Being too tight is the potential issue.Make sure you torque it to 80 ft-lbs. Thats more than enough
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
ehoff121
Re: (THE VIBERATOR)
Post by ehoff121 »
Quote, originally posted by THE VIBERATOR »Make sure you torque it to 80 ft-lbs. Thats more than enough76 ft-lbs. is the max recommended torque.
