Quote, originally posted by lovemyraffe »I am now officially sick of having my cheap-@$$ stock stereo not play CD's for who knows what reason. After talking with a few local shops about Peripheral, I've come to a few conclusions.1. This is the best one for the money2. I can just buy this and install it myself3. I must buy an adapter to install it to my stock radio4. I cannot install it myself or I risk destroying the entire universe5. Nobody nearby can give me a straight answerCan anyone tell me which kit I need and whether or not I need an adapter to disable the thing-a-ma-jig hiding under the drivers seat?
http://www.peripheralelectronics.com/For the 03-05 vibe you would need the ISGM73This kit comes with your harness all that is required is to hook up a constant and a negative wire, plug in to the port on the back of the radio, and set the dip switches gravey, gravey job. All you have to do is make sure you have the cd/aux button and your golden.To answer your questions.1. Yes Peripheral makes an awesome piece and can be found for under $1002. You hsould have no problem installing it a plug, 2 wires and 2 dip switches.3. Peripherals new kits include the harness you need.4. only if you attach a bomb5. no corners.Sorry Im a few days late on this, hope it helps.Peripherals website says that it will only work with 03-05 not compatiable with 06-currentAron
