Gearshift position on 2009 1.8L 4 speed automatic
jake75
Post by jake75 »
I read the manual but I am still confused.When in "Drive -3" the shift lever can move right - left. Does that make any difference?
sk8r78
Post by sk8r78 »
The purpose of the movement is to upshift or downshift manually. Allows you control of when to shift rather than the computer which has preset points. lets you stretch out a gear or downshift to use the tranny and engine to help you slow down.
northvibe
Post by northvibe »
the 1.8 auto I dont think it has the "manual" shift mode, thought only the GT did. If there is no - + next to it it is not a manual shift part. it is just the way the shift area is laid out as its wide so you can move down to 2 and L see its just a wide area, its so you cant shift into N from D with out moving it to the right and up. Must just be extra room in there to jiggle it left and right.
kowell
Re: Gearshift position on 2009 1.8L 4 speed automatic (jake75)
Post by kowell »
Quote, originally posted by jake75 »I read the manual but I am still confused.When in "Drive -3" the shift lever can move right - left. Does that make any difference? When in D, the car is in Drive. You have lower speeds available when going up steep inclines or other situations. 3 is 3rd, 2 is 2nd. D and 3 are not the same thing. Your transmission is a 4 speed.
2009 Vibe 2.4L 1SC - Red Hot Metallic
2011 Sienna V6 CE - Sky Silver
Re: Gearshift position on 2009 1.8L 4 speed automatic (kowell)
They got rid of the O/D OFF button for '09, right?So am I looking at it right by saying pushing it to the far left position keeps it in 3rd and locks out overdrive (similar to pressing the O/D off button on the older Vibes) and all the way right allows it to go into 4th gear?
PlatinumVibe08
Re: Gearshift position on 2009 1.8L 4 speed automatic (ColonelPanic)
Post by PlatinumVibe08 »
Quote, originally posted by ColonelPanic »They got rid of the O/D OFF button for '09, right?So am I looking at it right by saying pushing it to the far left position keeps it in 3rd and locks out overdrive (similar to pressing the O/D off button on the older Vibes) and all the way right allows it to go into 4th gear?That is correct!
2006 Lexus SC430 White Gold Crystal
2010 Lexus RX350 Matador Red Mica
2013 Lexus CT200h Starfire Pearl
jake75
Re: Gearshift position on 2009 1.8L 4 speed automatic (PlatinumVibe08)
Post by jake75 »
As Desi would say . . . that 'splains it.
