wire brush noisey pulleys=
jamesmetairie
Post by jamesmetairie »
if you was gonna replace tensioner and accessery belt wouldn,t it be a good idea to clean the pulleys surface that the belt rides on?? would you use a light wire brush to do so ??
Raven
Re: wire brush noisey pulleys= (jamesmetairie)
Post by Raven »
Cars as recent as the Vibe shouldn't have any corrosion on the pulley unless they've been submerged in water Sorry. If they're is crud in the grooves a light wire brushing should be fine.
