outside driver's door handle
joholste
Post by joholste »
ok so when i opened my door this morning i and all my great ultimate brute strength managed to pull the door handle off at the front pivot. has this happened to anyone else. can someone who has the capability to get the parts at dealer cost help me out? will it be a hard fix.
Re: outside driver's door handle (joholste)
I wouldn't blame your brute strenght, it's all about defective parts. Does it look anything like this? This happened to the Vibe my buddy used to own... The thing just broke off when he went to open the stupid door... http://forums.genvibe.com/zerothread?id=5687
joholste
Post by joholste »
yes exactly like that. is there anyway to fix it myself?
Re: (joholste)
If you can get a hold of the part number and find a cheap source for the part, yep, it can be done yourself. I don't have the procedure on doing it, but I don't think it would be too terribly hard.Hate to see it break though, that dog gone cheap plastic.
scherry2
Post by scherry2 »
this is what my parts list says:handle, outsideblackw/rpo-d75 r/l 88971449wo/rpo-d75 r/l 88969863 $21.61they also have blue 88971461 $20.85grey 88971456green? 88971460red 44u 88971458red 81u 88971459silver 88971455white 88971454I think the RPO-D75 is either a gloss or satin finish for black the 44u and 81u and salsa and lava hope this helps it should be easy to change. I would IM tnpartsguy and see what he could do for you
joholste
Post by joholste »
thanks scherry, one question is that the part numbers for a 05, and will they work for an 03?
scherry2
Re: (joholste)
Post by scherry2 »
don't see why not.
paulmig
Re: (joholste)
Post by paulmig »
I just had that same clip bust on my exterior 2003 vibe door handle (pass/rear). Were you able to acquire the part(s) and replace the handle yourself? Or is this a job better left to the experts instead of a do-it-yourselfer.
Danyeln
Re: Door Handle
Post by Danyeln »
Two years ago, when I was having my windshield replaced for the first time on my '03, the glass guy pulled the driver's side handle right off. They went over to the Pontiac dealer, came back and snapped the part right back on themselves. They paid for it but I think they said it cost about $30.
paulmig
Re: Door Handle (Danyeln)
Post by paulmig »
Yep, it's about like you said. A trip to the dealer ($52 yikes), remove the door panel and lock assembly and viola. (Viola = 2.5 hours = 4.2 beers)
hskater26
Re: Door Handle (paulmig)
Post by hskater26 »
joe, lay off the roids and stuff like this wouldnt happen
-2003 Base Vibe-2002 Ducati ST2
breezd
Re: outside driver's door handle (scherry2)
Post by breezd »
Quote, originally posted by scherry2 »this is what my parts list says:handle, outsideblackw/rpo-d75 r/l 88971449wo/rpo-d75 r/l 88969863 $21.61they also have blue 88971461 $20.85grey 88971456green? 88971460red 44u 88971458red 81u 88971459silver 88971455white 88971454I think the RPO-D75 is either a gloss or satin finish for black the 44u and 81u and salsa and lava hope this helps it should be easy to change. I would IM tnpartsguy and see what he could do for youI know this is a lil bit older thread, but I gotta get this fixed!I've got the Abyss two-tone... any idea on which black handle I would need to get? I'd guess its the w/o RPO d-75..... but I just wanna make sure...EDIT: Parts sites say "Front door - Lock and hardware - Handle outside - W/o body colorW/o body color Back 2003 - 2008"So I'd assume this is correct...?
THEN: 2003 Pontiac Vibe GT * Lowered * CAI * Sound SystemNOW: 2005 Infiniti FX35 RWD * Stock
breezd
Re: outside driver's door handle (breezd)
Post by breezd »
Anyone have an idea?
Not sure what RPO D75 Is... Perhaps check your service parts identification label in the glove box and that should tell you if you have that option.
kevera
Post by kevera »
Quote, originally posted by breezd »EDIT: Parts sites say "Front door - Lock and hardware - Handle outside - W/o body colorW/o body color Back 2003 - 2008"So I'd assume this is correct...?Yep,that's the one you need for the black handle.
