Monsoon Woofer Wiring
Forrest88
Post by Forrest88 »
The wiring diagram referred to in the forums for Stock Moon & Tunes system DOES NOT show the woofer wire connection, just the tweeters, and front and rear door speackers. Is the woofer wiring run through the regular rear speakers wires?I ask because Crutchfield says I need a PAC OEM-2 (Universal Factory Sound System Interface) to accomodate installation of my Pioneer Head Unit. Is this necesary or can the woofer be activated with the stock wiring through the stock M&T 200 Watt outboard amp?Thanks to anyone who can enlighten me here.FORREST
dianebrat
Re: Monsoon Woofer Wiring (Forrest88)
Post by dianebrat »
Quote, originally posted by Forrest88 »The wiring diagram referred to in the forums for Stock Moon & Tunes system DOES NOT show the woofer wire connection, just the tweeters, and front and rear door speackers. Is the woofer wiring run through the regular rear speakers wires?I ask because Crutchfield says I need a PAC OEM-2 (Universal Factory Sound System Interface) to accomodate installation of my Pioneer Head Unit. Is this necesary or can the woofer be activated with the stock wiring through the stock M&T 200 Watt outboard amp?Thanks to anyone who can enlighten me here.FORRESTThe PAC OEM-2 will do fine, the sub-woofer is tied in via the M&T amp.Diane
last of the '06 AWDslava red monotone, preferred, sport, and side airbags
Sublimewind
Post by Sublimewind »
What she said..^^^
Forrest88
Re: Monsoon Woofer Wiring (dianebrat)
Post by Forrest88 »
THANKS FOR THE REPLY, DIANE. WHAT HAPPENS IF i DON'T USE THE OEM 2? I HAD A 04 VIBE WITH M&T AND DID NOT USE IT AND IT SEEMED TO WORK FINE, YET CRUTCHFIELD SAYS ON MY 06 IT COULD OVERLOAD AND PERHAPS DAMAGE THE AMP. TRUE?
dianebrat
Post by dianebrat »
Quote, originally posted by Forrest88 »THANKS FOR THE REPLY, DIANE. WHAT HAPPENS IF i DON'T USE THE OEM 2? I HAD A 04 VIBE WITH M&T AND DID NOT USE IT AND IT SEEMED TO WORK FINE, YET CRUTCHFIELD SAYS ON MY 06 IT COULD OVERLOAD AND PERHAPS DAMAGE THE AMP. TRUE?ack.. OW my eyes hurt.. all caps = bad!But to answer your question, can you run without the PAC OEM-2? yes, as long as you're ok with some distortion and have no intention to try and shake the wheels off the car.I run a JVC KD-AVX44 right into the M&T amp, and it's ok, but I don't listen very loud, and I know if I cranked it up too high I'd start destroying components, but I'm old and not interested in my windows thumping with the music
When I first installed an aftermarket HU, I didn't use one of those thingies - it worked fine but I had excessive white noise at lower or no volume. It was very loud though! I got that cheap Scosche line level converter thingamajig to attenuate the signal coming from my new HU and that really cleaned things up.
lightsup
Post by lightsup »
If your HU has preamp outputs, couldn't you wire those directly to the monsoon amp, without having to use the Scosche converter? Wouldn't the sound be better doing things this way?
dianebrat
Re: Monsoon Woofer Wiring (lightsup)
Post by dianebrat »
Quote, originally posted by lightsup »If your HU has preamp outputs, couldn't you wire those directly to the monsoon amp, without having to use the Scosche converter? Wouldn't the sound be better doing things this way?For some reason I'm fairly sure there are threads about this and they say it won't work, I suspect it's because the line level is too low, but I'm just really guessing until someone more knowledgeable chimes in.
Forrest88
Re: Monsoon Woofer Wiring (ColonelPanic)
Post by Forrest88 »
Thanks for all the input regarding the OEM wiring unit to accommodate the new HU. It appears the best sound will come from adding this "adapter" into the mix so will procede with getting one.Thanks Much!FORREST(sorry about the CAPS wacking your eyes, Diane)
