Yes, I know, I'm the Gasket King lately. Should NOT have re-used most of the gaskets like I did.Anyways........replaced the Supercharger gasket, and got the tensioner replaced. Now I have even a higher whistle upon accelerating, even when I'm parked and I rev it. It's also been idling a bit worse lately.Thoughts? Would a bad header gasket cause all of that? I'm thinking it would have to be exhaust.
Check anything that could have a gap.Header, throttle body, intake, exhaust manifold, really anything that is connected. I have a rough idle problem and it's because of a vacuum leak in my throttle body, right where the spacer is. I can't fix it and it's not throwing a CEL so i dont mind, but it does act up from time to time.
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
