I have an 2006 Vibe with the M & T set up with the tweeters in the corner in front of the door window. This is called the window sail correct? If so, where can I get the regular window sail (without the screen) so I can make a custom mount for new tweeters (mine are blown). Would a junk yard be a good place to look first?
2006 ABYSS VIBE: 20% TINT ALL AROUND FRONT & REAR SPLASH GUARDS MAGNAFLOW CAT-BACK EXHAUST GOODYEAR EAGLE GT (235/45/17) WITH TC WHEELS (SUMMER) DUNLOP WINTER SPORT M3 (215/55/16) ON STOCK ALLOYS (WINTER) AUTO VENTSHADE WINDOW VENTS PLUS SUNROOF VENT K/N AIR FILTER,OTHER DRESS-UP GOODIES...
The M&T set up for the tweeters is very specific. And the only way that I could mount the aftermarket tweeters in the same location is to "modify" the sail that's already there. And I want to make it as clean as possible that's why Im looking for the plain sails so that I can cut a nice hole to mount the aftermarket tweeters in.
Remove the sails and door panel. The stock tweeter is mounted on a bracket you can take out easily, unscrew the tweeter from the bracket and jb weld the new tweeters in the same location. Works great for 3/4" tweeters, might not for larger ones.
Does anyone have a recommendation on tweeters? Should I go with factory (which run about $120 a pair) or go with a good set of aftermarket ones?
