Removing rivets from stock speaker mounts
DeClerq
Post by DeClerq »
I bought some new speakers for my '09 and found out the stock speakers are held in by rivets (what's wrong with screws??). Is there a special way to get them out or do I just need to get a drill and go to town? Thanks!
'09 Mazda5 Grand Touring'04 Vibe - M&T, Power Package, Protection Package
Markmysite
Re: Removing rivets from stock speaker mounts (DeClerq)
Post by Markmysite »
Yup, just drill them out. For the front you will need to use the plastic mounts or the window won't shut (No issue in the back though). Just shred the factory speakers and use a pair of snips to cut the plastic parts in the back holding the speaker in.
2007 Vibe (base-5 speed man)MODS = Added CC, 15% Tint, New wheels, Nav/DVD, Polk speakers, Infinity sub/amp, Console Outlet, ECO MODS = ScanGauge II, Perm. alum. grill block, belly pan, Removed antenna, Tire pres. 44 psi Future ECO MODS = Removable lower grill block, Clear fog covers, 195 deg. therm, Rear spoiler, Full belly pan
DeClerq
Post by DeClerq »
I got one of the front speakers replaced. Not sure what you mean by using plastic mounts. The whole speaker came out, I just had to drill some new mounting holes for the bracket. Window works fine.
kunkstyle
Re: (DeClerq)
Post by kunkstyle »
Some speakers are too deep to mount in the stock locations without using a bracket or re-use the existing bracket from the vibe which brings the speaker closer to the interior side of the door panel. Too deep a speaker will block the window from going all the way down.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
DeClerq
Re: (kunkstyle)
Post by DeClerq »
Thanks for the posts - you guys saved me a ton of work. I never would have thought to reuse the old speakers as "brackets" for the new ones. What I did was leave the stock speakers riveted in place and just cut out the speaker part, then I screwed the new speakers to the old ones. Worked great. I think I installed the last three speakers in less time then in took me to get the first one put in.
vibolista
Re: (DeClerq)
Post by vibolista »
No pictures of this procedure? Sure would be helpful for reference. What speakers did you install. Results?
wyatt89
Post by wyatt89 »
I didn't drill mine, the rivet was so soft that I just used a pair of nippers to cut it off then reach back behind and grab the other half.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
