I'm reminded by events today to NOT overcomplicate things, and don't make quick assumptions.Today, after checking connections @ MFA module and all harnesses going across or up or anywhere, I decided to pull the dome light assembly down and see what I could learn with a voltmeter.I didn't expect much, because BOTH dome light assemblies couldn't be bad at the same time, right?After confirming that the switch was NOT doing what it should, I disassembled the switch (watch out for the ball bearing jumping out), and cleaned/scraped the corrosion of the switch terminals.I reassembled, reinstalled, tested good and did the same with the other dome light assembly.I was reminded of something that happened to me 25 years ago when I serviced car stereos. A cute young thing came in with her VW and said the radio was dead. I did the usual-check for a thump when turning on after verifying 12v+, and I got no thump.I pulled the radio because both speakers can't be bad at the same time, right?Bench test radio-OK.HUH?Bring car back in to check speakers-both open.Felt like a toad.Thanks to all who replied to my original post and tried to help.Frank
McGovernmcgvector@gmail.com
