x
micheles_bad_vibe
x
Post by micheles_bad_vibe »
x
Last edited by micheles_bad_vibe on Wed May 09, 2012 2:12 pm, edited 1 time in total.
ragingfish
Re: lag (micheles_bad_vibe)
Post by ragingfish »
I don't have problems...make sure you start accelerating before you get to the hill...that momentum help keep you going...You could also disable the O/D to get a little more power...I do that a lot, and have yet to see any major impacts on fuel economy as a result of it...
2009 PONTIAC G8
good vibes
Post by good vibes »
I sort of have the same issue, I think it is lack of HP but I'm no tech guy, I usually get a nice speeding start and give it all I can, I make it but yeah it is a bit sluggish, much better than my old nissan pickup with 32" tires.
My Car: 2003 Vibe AWD Shadow/Graphite My Options: Vibe Rubber Floor Mats, Vibe Back Seat Pouches w/ First Aid Kit My Extras: Anti-Fatigue Mat Cut To Fit, PIAA H4 Headlights, grafixwerks stuff, yakima bike blocks, roof rack with land shark for my kayak, and loadwarrior, hella tripple tone air horns (wanna hear a loud horn? get these!) Rockford Fosgate fanatic 6 1/2".
KSNeptune
Post by KSNeptune »
I've got a base vibe with auto transmission. On long hills it will downshift to keep up to the speed set with my cruise control. If you've got a manual transmission, try downshifting a gear. The higher the engine revs the more horsepower and torque it has. The Vibe hasn't got a low wind resistance number, and it weighs more than smaller (shorter) cars, so keeping the engine in it's "economy" high gear means it's not going to be very good at hill climbing.So Downshift. Let the engine have some higher revs.KSNeptune
yank dini
Post by yank dini »
I downshift and disable the O/D all the time. Basically I only do it to get that "running start" then I throw it back to O/D to get that last push. That's when that low end grunt kicks in. I'm floating by then......
TRICKEDVIBEGT
Re: lag (yank dini)
Post by TRICKEDVIBEGT »
should had gone with the gt model you would never have probs with power thats for sure
yank dini
Re: lag (silverawd26)
Post by yank dini »
if you're talking about me.....I cant drive a stick (another reason why I opt for base)****DUCKS OUT OF POST*****
yank dini
Post by yank dini »
yeah but Im still look for a dealer that knows for sure when they will come in to begin the dealer installations
yank dini
Post by yank dini »
yeah I will be thereActually I am rushing to do as many mods as I can before the meet minor or major
canadavibegt
Re: lag (yank dini)
Post by canadavibegt »
I cann't believe a car person like you can not drive a stick.... I made my gfriend learn to drive a stick cause I was sick of driving a manual trans............. How boring..... And she is starting to like it after about 4 months.Oh ya the power thing no sugestions other than those posted... Cause I drive GT
Canada Rocks View pics of my car here. http://www.cardomain.com/member_pages/v ... _id=345207
PBFlash
Re: lag (canadavibegt)
Post by PBFlash »
Anyone could learn to drive a stick in a few hours or less. When I picked up my GT I had only driven a stick twice in my life and it was over 6 years ago. I stalled it a few times but by the time I got home (1/2 hour later) I was doing great. A lot of people are saying they got the base so they could put the supercharger in it. I'd like to see how many actually do it once it comes out.
Satellite Vibe GTMoons and Tunes Package with 6-Disc In Dash CD, Safety/Security/Power Packages, cargo mat. 35% tint all around (except windshield)18 in Motegi Racing MR8 Wheels/Nitto NT 555 225/40ZR-18 tiresStainless Steel Exhaust TipInjen CAIPics of my Vibe CarDomain.com
micheles_bad_vibe
Re: lag (PBFlash)
x
Last edited by micheles_bad_vibe on Wed May 09, 2012 2:13 pm, edited 1 time in total.
ragingfish
Re: lag (trickedvibegt)
quote:should had gone with the gt model you would never have probs with power thats for sureUnfortunately, I couldn't afford the GT at the time, and I can't drive stick yet...emphasis on YET...Which leads me to another question: is it true that whenever you come to full stop with a manual you have to go to neutral or the car stalls out? What's THAT all about???
2009 PONTIAC G8
millster
Re: lag (ragingfish)
Post by millster »
quote:Which leads me to another question: is it true that whenever you come to full stop with a manual you have to go to neutral or the car stalls out? What's THAT all about???That would be a big negative. The only time you need to put the car in neutral is if you want to let your foot off the clutch or get out of the car with the engine still running. I'll do it sometimes if I'm sitting through a long light just so I don't need to be holding the clutch in (just put in in N and let the pedal out).
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
1986 Jaguar XJ6 Vanden Plas (GM Drivetrain Conversion)
2007 Outback XT EJ257 2.6L Build
ragingfish
Re: lag (millster)
Wait. Why do you hold the clutch in at a light? Can't you just downshift to 1 and let go?
2009 PONTIAC G8
millster
Post by millster »
No sir. The clutch is the link between the engine (turning) and the wheels (not turning in this case). The clutch in a manual transmission seperates the two and allows the engine to keep running while the wheels are at rest, or engages the two and starts the wheels turning through the gears in the transmission.http://auto.howstuffworks.com/clutch1.htm
-Millster-
dmitri
Re: lag (millster)
Post by dmitri »
Holding your foot down on the clutch disengages it, so the flywheel is spinning freely; when you let go it engages and the power goes to the trans. It is actually better for the car to keep it in neutral at a stoplight then hold your foot on the clutch because it's not good for the cluth mechanism to keep it spinning like that. Raging Fish: about the NJ car meet...am I the only young one going?? i dont want to be the only 17 yr old around no one my age...
DopeVibeGT
Re: lag
Post by DopeVibeGT »
Driving a stick is very easy. Shouldn't take anyone more than a few hours to get it down. I learned on a stick. As for losing power, it's a 4 banger. Unless you have a little HP under the hood (Like the GT), they will die up hills and you will have to rev it. The base Vibe shoudnt have too much trouble with 130HP.I'm still willing to bet $$ on my GT with it's current mods vs a S/C base. Any takers?
dmitri
Re: lag (DopeVibeGT)
Post by dmitri »
definitely a GT will beat a base with supercharger. Maybe itll have some trouble with a base with stick tho...I have a few mods tho so i'm safe
Chris
Re: lag (dmitri)
Post by Chris »
Regarding the up-hill thing, it's not hp that's the prob, its the RPM that the HP is available. I'll bet you guys with GT's struggle to go up a steep hill in 6th at say, 80 kmh as this will put you around, what... 2500 rpm? The issue is that even though we have 130 and 180 hp, it does not come on until relatively high rpm. Peak power (for base) is around 4-5000 rpm while I turn around 3000 or slightly less on the highway probably giving me less than 80 hp available. I downshift, get into the powerband, and off we go... no probs. For auto's you'll probably have to floor it or get out of OD or something but, as long as your car is turning over 4000 rpm, you should be just fine! Please note, these rpm and HP numbers are a rough estimate. Check out a dyno chart and you'll see where your power comes on.Regarding the Supercharger vs. GT... I'm willing to bet in all normal driving circumstances, the supercharged base will take a GT. Here's my rational. The SC adds a whole lotta torque at low rpm thus giving the base ample power immediately while the GT guy has to drop several gears or get an AMAZING launch. Where the GT will most likely shine is top end / top speed as the GT has a bit more HP. 'Round town... my money's on a SC Base. This is what I'd suggest happens:0-60 SC Base1/4 close but I'll take the SC Base maybe the pros will launch better than the average guy (like me!) but the SC will have the edgeAnything more than 1/4... I'd have to say GT.Sigh, I'm not supercharging my car so this is all moot to me. You guys who are actually DOING something, please let me know how it turns out!
Chris Car: Base Abyss Vibe 5 spd + Mags & Power Pkg - no modsBike: Suzuki GSXR1100 4xK&N's V&H pipe and headers
yank dini
Post by yank dini »
quote:I cann't believe a car person like you can not drive a stick.... I made my gfriend learn to drive a stick cause I was sick of driving a manual trans............. How boring..... And she is starting to like it after about 4 months.Oh ya the power thing no sugestions other than those posted... Cause I drive GTEven Jordan has his weaknesses
yank dini
Post by yank dini »
K & N air filters make a differenceTry one....
micheles_bad_vibe
Re: lag (yank dini)
x
ragingfish
quote:i was thinking about that too.but today i did turn off the o/d when driving up the hill.... made a super difference.... i got up the hill with no probs at allThat's a fun little button, isn't it.
2009 PONTIAC G8
rubberman
Post by rubberman »
Its the poor gearing in the transmission the base car would be better served with the six speed fromm the GT
Car&Bike Pics http://www.cardomain.com/ride/2355922/1New Kumho712(summer225/50/16)195/65/15 Dunlops(winter)03 Vibe 49,000kms gone!!!!!New Battery/window rubber pass doorTwo seats fixed(coming apart at the seams)Transmission?,Tires that sound like mudders on a truck(Contis) 18,000kms done/noisey A/C Compreser/poor paintRadio(no am)2 days old ,door speaker replaced
ragingfish
Re: lag (rubberman)
quote:Its the poor gearing in the transmission the base car would be better served with the six speed fromm the GTWe're talking automatic, though, not manuals.
2009 PONTIAC G8
Lorin
Post by Lorin »
The key when hill climbing is to not be afraid of the downshift. You have to keep these engines turning! It was the hardest thing for me to get used to, having previously driven engines where the torque is greater at lower rpm's. For some reason my 12 year old daughter thinks its really exciting when I downshift on a hill, especially if I'm passing a slow-poke. lol
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
