What is this part?
Bri in Mtl
What is this part?
Post by Bri in Mtl »
New member and 1st post.Bought a used 2005 w/only 35,000K and found this piece of plastic in the glove box.Anyone know where it goes and what it's for?Thanks in advance.
bull77
Post by bull77 »
I think I've seen that piece before --- check the seatbelt buckle by the floor, I think its the cover..
Bri in Mtl
Doesn't appear to be it.
BlueCrush
Re: (bull77)
Post by BlueCrush »
Quote, originally posted by bull77 »I think I've seen that piece before --- check the seatbelt buckle by the floor, I think its the cover..Close! It goes on the REAR of the front seat rail next to the floor. Check those and you'll see where and how it goes on. It was probably kicked off by a rear passenger at some point when it was owned by the previous owner. It was probably in the glove box because it is a pain in the a$$ to get back on. Good Luck!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
lovemyraffe
Post by lovemyraffe »
Quote, originally posted by BlueCrush »Close! It goes on the REAR of the front seat rail next to the floor. Check those and you'll see where and how it goes on. It was probably kicked off by a rear passenger at some point when it was owned by the previous owner. It was probably in the glove box because it is a pain in the a$$ to get back on. Good Luck!I was going to say the same thing.
Bri in Mtl
AHA!! That's it!Thanks a bunch!
AKLGT
Post by AKLGT »
yep, rear seat belt bolt cover.
AKLGT1998 Subaru 2.5RS
zionzr2
Post by zionzr2 »
+1 to the othersI guess I'm a bit late to the party!
BlueCrush
Re: (zionzr2)
Post by BlueCrush »
Quote, originally posted by zionzr2 »+1 to the othersI guess I'm a bit late to the party!You need to be a little quicker on the draw...Wild Bill!
My Fleet:
I swear mine would fall off if I looked at the seat track, those stupid things! And I could never get them back on right.
