New Deck
WaveAction
New Deck
Post by WaveAction »
well i purchased a new deck for the vibe, havent installed it yet, but will shortly! very excited and love it so far(looks wise) i picked up the Alpine CDA-9886, got it from a friend.
kunkstyle
Re: New Deck (WaveAction)
Post by kunkstyle »
That's a nice packing job there...Looks sharp - good luck on the install!
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
waveresponder
Post by waveresponder »
nice! cant wait to see pics of it installed!
Sublimewind
Post by Sublimewind »
That is a GREAT deck... good job mang... !!!
WaveAction
thanks, just gotta do the wiring still and plop it all in..i'd like to solder it and use the heatshrinks to make it nice and clean...so just matching up the wires now and gotta find/buy a soldering kit, not expensive and its handy if i need it later on
WaveAction
well im done the soldering part of the harnesses...now it's just a matter of taking out the stock deck and slapping in the new one..will have pics up tomorrow after work! heres a few pics of the harnesses, cut the Alpine one down quite abit, then did the barrel knot as sublime posted in his "how-to" then used heatshrink tubes to cover them up..theirs a few i forgot to put the tubes on first then solder, thats why theirs about 4 or 5 that has tape on them insteadstock harness(bottom) and the alpine harness on the topmy "barrel knot"harness all completei had 4 left over wires 3 from the alpine harness and 1 from the stock one so i used a heatshrink tube and folded the end of it in to make a noose type thingand heres a couple of of the connections after soldered and heatshrunk
keithvibe
Re: (WaveAction)
Post by keithvibe »
whats with the photos of wires... wheres the photos of the install?
WaveAction
you obviously didnt read the first sentence of the post i said im installing it tomorrow..
kunkstyle
Re: (WaveAction)
Post by kunkstyle »
What's the hold up? The wiring is what takes the longest.
keithvibe
Re: (WaveAction)
Post by keithvibe »
I did buddy.. just buggin ya and by the way put some dame shoes on
WaveAction
lol and get my white carpet dirty? i think not! and ya the wiring took me about an hour..but had other things to do so didnt get to the installing..thats why it's tomorrow
Burns1210
Re: (WaveAction)
Post by Burns1210 »
Instead of connecting the wires like that before soldering, I've found it easier hooking the exposed wire together like two candy canes, then soldering.
2008~Auto~Platinum~Monsoon~Sport Package
WaveAction
i found it easier like this so i can get the heatshrink tubes over top of them..i only had the 1/8th diameter tubes but it worked good, doesnt really matter how you do it
Sublimewind
EXCELLENT work man.... !!! Those knots look MUCH better than the ones I posed... Maybe I could borrow that one pic for my install tutorial?? It would definitly represent what I was trying to show MUCH better...Now, for the install pics..
Sublimewind
Re: (Burns1210)
Quote, originally posted by Burns1210 »Instead of connecting the wires like that before soldering, I've found it easier hooking the exposed wire together like two candy canes, then soldering.That technique "works" but doesn't lay as flat as a barrel knot, it also has a possibility of stressing the solder to the point of failure(less surface area conected by solder), more so than the barrel knot but that is somewhat far fetched.
WaveAction
Re: (Sublimewind)
Quote, originally posted by Sublimewind »EXCELLENT work man.... !!! Now, for the install pics.. so far i love the deck, i gotta play around with it abit and see what i can and cant do..and of course i forgot my cable for the ipod so i may have to take the deck out again just to plug it in..unless i can find away to get my hand up behind or even through the glove compartment to get to the loose wire
kunkstyle
Re: (WaveAction)
Post by kunkstyle »
Quote, originally posted by WaveAction »and of course i forgot my cable for the ipod so i may have to take the deck out again just to plug it in..unless i can find away to get my hand up behind or even through the glove compartment to get to the loose wireGood luck with that. I had to fish mine in from the top down.Looks sharp in the Vibe. I hope you at least had some socks on when you went out to the car...
keithvibe
Post by keithvibe »
looks good buddy
WaveAction
lol i was at work..so yes i had socks on..the other pic without socks was in my room smartass
kevera
Re: (WaveAction)
Post by kevera »
You must be new,taking all these pics and none with the radio on.
WaveAction
i am new i will get a pic of it on..and another at night
kevera
Re: (WaveAction)
Post by kevera »
Quote, originally posted by WaveAction »i am new Ahahaha,cool deal.
TinleyJake
Re: (WaveAction)
Post by TinleyJake »
I have the same radio and install kit. It's like you took a picture of my dash. Best receiver I have ever had and I've gone through 6 different ones in the last two years. Unfortunetly, even though I've only had this unit for 3 months, I'm replacing it next week with the 9887 model with the built in crossovers in order to run my speakers active.The Ipod controls with the dedicated cable are the best I've used. I installed the cable in the opening below the radio so I had easy access to remove the Ipod.Are you planning to use the USB?
WaveAction
probably not gonna use the USB...i have my ipod hooked up to it..i have it running underneath the shifter along the center console..and ya..havent really done much other then that..but so far i love this receiver aswell..couldnt be happier..just 1 little thing annoys me...is when i first put the faceplate on..sometimes it takes a few tries to get it on properly
Sublimewind
Re: (TinleyJake)
Quote, originally posted by TinleyJake »I have the same radio and install kit. It's like you took a picture of my dash. Best receiver I have ever had and I've gone through 6 different ones in the last two years. Unfortunetly, even though I've only had this unit for 3 months, I'm replacing it next week with the 9887 model with the built in crossovers in order to run my speakers active.The Ipod controls with the dedicated cable are the best I've used. I installed the cable in the opening below the radio so I had easy access to remove the Ipod.Are you planning to use the USB?I want to hear more about your active set-up... As you are new, I don't know you yet(welcome BTW), and I would like to make sure you are getting into "active" correctly... I'll be running active through an Alpine h701 processor with the c701 cotroller, no HU, just a modded xBox running optical into the 701...!!! woot woot.... lol...
Celtic_Curse
Post by Celtic_Curse »
Great choice in Decks. I'm a big Alpine fan. great job on the install.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
WaveAction
thanks man..i really like the alpines too..it was either that or a pioneer..but liked the features and the price i got for the alpine so i picked it up..love it so far..i usually have it at 7..and it's loud lol..so im sure to blow my stock speakers soon
