cds won't play
mstrse
cds won't play
Post by mstrse »
I have a 2005 vibe and just over the past few months certain cds will not play. I've tried cleaning the cd player with a cd cleaner disk and it did help but only for a while. Some of the cds it will not play are brand new, i will buy them and put htem in and they make a skipping noise then skip through out the whole song. I don't know what to do does anyone have any advice? Please
MRCN RCE
Post by MRCN RCE »
welcome to the family.if it's still under warranty, you can get it taken care of for free. if not, you can always check here or ebay and find another one. the best thing would be to go with an aftermarket one
GENVIBE: THE PLACE WHERE ALL THE COOL KIDS HANG OUT05 GTK&N SRI, exedy clutch, fidanza flywheel, Neo-GensLIFT: the equivalent of viagra for your tach n speedomy garagehttp://forums.genvibe.com/zerothread?id=24931
Raven
Re: cds won't play (mstrse)
Post by Raven »
The stock head unit is junk. I have a total of 5 of them and none work properly. Several have burnt displays and some have various other problems.
kunkstyle
Re: cds won't play (Raven)
Post by kunkstyle »
Quote, originally posted by MRCN RCE »the best thing would be to go with an aftermarket one+1The GM stereos are garbage, doesn't seem to matter which model they're in.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
Blueridge9
Post by Blueridge9 »
I had the same problem with CD player. Although you could get a new one I have another option to consider as told to me by somebody on GenVibe. If you like to recycle and get things cheap try ebay. I just bought one from LKQ (a power seller). They sent it quick and it's working PERFECTLY. See below. It came with a warranty but no install instructions but it is just like the one you remove so it's easy.http://cgi.ebay.com/ebaymotors...sting
Blueridge9 2004 Base, 1.8L "The Vibe is a melding of muscular looks, ..utility & economy, sportiness & road-hugging tractability." -Road & Track Magazine Sept. 2008 Pictures: http://s278.photobucket.com/user/blueridge9/library/" onclick="window.open(this.href);return false;
Sublimewind
Post by Sublimewind »
CD player cleaning CD's aren't cutting it... it's nothing more than a brush that wipes the crud from one side of the laser lense to the other... A real cleaning will involve removing the unit, opening it to some extent to expose the laser, and wiping it down with a Q-tip dipped in Windex or IPA, drying and re-assembling/re-installing.. I've done HUNDREDS of CD player cleanings and it's the only 'good" way of doing it... THEN once it's done, there is no real telling if it will work properly... As a CD laser pick-up ages it get week, there ARE adjustments for it, but you have to have a test bench and a ossilliscope to do it and the service manual to go along with it.. Some go for EVER, some don't
