ABS
caliguy78
ABS
Post by caliguy78 »
This is somewhat of a dumb question, but how can I tell if I have ABS or not? I purchased a used VIBE and was told it had ABS. When I start the car, the ABS light does not come on.
VforVIBE
Re: ABS (caliguy78)
Post by VforVIBE »
Check the front of the break peddle, it will say ABS if the car has ABS.
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
engineertwin2
Post by engineertwin2 »
If you are still unsure after that, you can always have a dealership check the VIN to determine what was the manufacturer installed options were. ABS is installed at the factory and this should be in the database, tied to the VIN.
VforVIBE
Re: (engineertwin2)
Post by VforVIBE »
Or you can check the Regular Production Option (RPO) Codes can tell you what your Vibe was equipped with when it left the factory. they can be found inside Glove box. You are looking for the code JL9 (GT) or JM4.http://forums.genvibe.com/zerothread?id=6558
engineertwin2
Anyone know if they had ABS on the Vibes with rear drums? Wasn't sure they did. If not, that might be another way to check.
prathman
Re: (engineertwin2)
Post by prathman »
Quote, originally posted by engineertwin2 »Anyone know if they had ABS on the Vibes with rear drums? Yes, the ABS option was available with regular drum brakes in the rear. One of ours if equipped that way.
Mavrik
Re: (prathman)
Post by Mavrik »
Real easy way... go drive it and hit the brakes HARD. You'll know if you have ABS or not.
Sublimewind
Re: (Mavrik)
Post by Sublimewind »
Quote, originally posted by Mavrik »Real easy way... go drive it and hit the brakes HARD. You'll know if you have ABS or not.+2
lovemyraffe
Post by lovemyraffe »
Quote, originally posted by engineertwin2 »Anyone know if they had ABS on the Vibes with rear drums?Mine has rear drums and ABS.Quote, originally posted by Mavrik »Real easy way... go drive it and hit the brakes HARD. You'll know if you have ABS or not.+3
LeatherVibe
Re: ABS (caliguy78)
Post by LeatherVibe »
Until 2006, you got both ABS and the low pressure tire monitor system. If you have the little tire picture on a button next to your hatch release, you have ABS. If you lift the hood and see about 4 grey hoses stacked next to the passenger strut tower, you have ABS.
caliguy78
Re: ABS (caliguy78)
Post by caliguy78 »
Thanks for all the replies. As it turns out, I don't have ABS.
Re: (Mavrik)
Quote, originally posted by Mavrik »Real easy way... go drive it and hit the brakes HARD. You'll know if you have ABS or not.Or better, without doing any sort of damage to brake components.... just turn the key on and look for an ABS warning indicator.
Image Image
Mavrik
Re: (ColonelPanic)
Post by Mavrik »
Quote, originally posted by ColonelPanic »Or better, without doing any sort of damage to brake components.... just turn the key on and look for an ABS warning indicator. thats not as fun though. Besides... everyone should experience brake lock up at least once to know what can happen. And it wouldn't hurt anything more then take a few miles off your tires lol
