Mid Spoiler "Butcher Job"
bckersey
Post by bckersey »
A person I know who works at a Pontiac dealership said that in order to install the mid spoiler, the installer has to drill a bunch of holes in the tailgate. These holes end up with bare metal edges on them. So the tailgate then has to be re painted to prevent rust. He said that all in all, it is not a good idea to drill holes in a car, but this is the only way to hold the mid spoiler on the car because adhesives aren't strong enough to support it.
bckersey
Re: Mid Spoiler "Butcher Job" (silverawd26)
Post by bckersey »
"What Pontiac Dealer?"Jim Causley Pontiac/GMC in Mt. Clemens, Michigan.
ragingfish
Re: Mid Spoiler "Butcher Job" (bckersey)
Post by ragingfish »
I would think they would have designed the spoiler to be attached without annihilating the tailgate...
2009 PONTIAC G8
Vibe Rater
Post by Vibe Rater »
Anyone who would drill a hole anywhere in the metal of a car is a butcher.
Jethro
Re: Mid Spoiler "Butcher Job" (Vibe Rater)
Post by Jethro »
Butcher? I don't think so.All you have to do is paint the edges of the newly drilled holes to seal the metal at that point. You do NOT have to repaint the hole darned hatch unless you REALLY screw things up (drop the drill prehaps?).I drilled holes in the trunk lid of my Civic when it was 3 days old to mount a prepainted factory spoiler. The dealer wanted $800 for the spoiler installed - I got them down to $400 uninstalled. $400 for 1/2 hours work - I don't think so unless I'm the one getting paid instead of the one paying. Had my Honda for 9.5 years and never had a single problem - here's hope this Vibe does as well.
Vibe Rater
Re: Mid Spoiler "Butcher Job" (Jethro)
Where I live they pour the salt to the roads, so any hatchet job is an invitation to rust, and rust it will. Touching up the paint isn't nearly the same as a factory paint job, with 'E' Coat and primer under the paint.
NovaResource
Post by NovaResource »
quote:A person I know who works at a Pontiac dealership said that in order to install the mid spoiler, the installer has to drill a bunch of holes in the tailgateWhat?! It's not held on with tape or magnets or bailing wire?!quote:These holes end up with bare metal edges on them. So the tailgate then has to be re painted to prevent rust.You don't have to repaint the whole tailgate all you have to do is paint around the new holes with touchup paint. The spoiler will cover the holes so teh touchpaint doen't have to be perfect. It just has to cover the bare metal.quote:He said that all in all, it is not a good idea to drill holes in a carReally? Does he know there are holes drilled in every Vibe to hold on the fenders and doors and roofrack and .........
Herb
Post by Herb »
quote:What?! It's not held on with bailing wire?! .........All I can say is you are a city slicker.....Twine from where I come from. Perhaps, but depending on what you tieing up. I use baling wire to tie bales of cardboard for recycling. I doubt twine would hold 1100lbs of cardboard.
ragingfish
Re: Mid Spoiler "Butcher Job" (Herb)
I used to work at Target...they have massive cardboard balers in the back...they crush hundreds and hundred and hundreds of boxes into a cube about 8 by 8 by 8...give or take...and they use a heavy steel wire to bind it all together and send it off for recycling...aka bailing wire.
2009 PONTIAC G8
ragingfish
Do they really use twine on hay?800 LBS of hay?!?!? I can't imagine hay weighing that much! ROFL!
2009 PONTIAC G8
ragingfish
Wow. Learn a new thing everyday!
2009 PONTIAC G8
NovaResource
quote:As for the midgate... If you took off the inside panels of the hatch, primered the inside and just rust proofed it and sealed the screw holes with silicone or rtv sealer, wouldn't that work just as good?Yes it would. That's my whole point.
Sub-Vibe-R
Re: Mid Spoiler "Butcher Job" (NovaResource)
Post by Sub-Vibe-R »
BTW, anyone know how to install safely a spoiler without drilling sone hole to bolt it on the car? From my part, I don't know how. Every single spoiler needs holes to be installed.
satur9
Post by satur9 »
the spoiler from apc for the matrix comes with 3m tape but i wouldnt trust it.besides i didint think you could just buy the peices minus installation. i would diy it anyway... im horrible with paint and sealer and stuff. the body kit and spoilers is a job id leave to the dealers.most of them know what they are doing.
DopeVibeGT
Re: Mid Spoiler "Butcher Job" (Sub-Vibe-R)
Post by DopeVibeGT »
To do the right install, you HAVE to drill holes for a spoiler. You could put it on with tape, but then you'd be picking it up off the road in the future. As was said, all you need to do is touch up the bare metal from the drill. If it's like most spoilers, theres a rubber seating gasket that goes around the base of the spoilers, so no water will get in there anyway.
Z600
Post by Z600 »
Yeah, I notice this guy hasn't posted back. Musta' realized he didn't know what he was talking about. I bet he get all his exterior add-ons from Auto Zone... if it ain't got double sided foam tape, it ain't legit! ~~Z600
-->'03 Base Vibe, Salsa Red--> Auto Trans --> Factory Aluminum Wheel Upgrade w/ Michelin Hydroedge Tires--> Power Stuff--> Also: Mr. Grille Inserts, Bug Deflector; K&N Air Filter, Bosch Platinum +4 plugs, Lots of Pretty Overlays, Super-cool Reflective Orange Pinstripe
Z600
Re: Mid Spoiler "Butcher Job" (Z600)
Post by Z600 »
Oops... just realized this was a seriously dead thread. Sorry!~~Z600
