Where is AM Antenna
loren
Where is AM Antenna
Post by loren »
I am thinking about having my windows tinted, and the window tint has some metal in it. The installer said that it will interfere with my AM radio, because the AM antenna is in the rear window defroster. I listen to a lot of AM radio, and don't want to loose any quality. Does anyone know a way around this issue, other than using a cheaper tint that doesn't have the metal component to it?ThanksLoren
ragingfish
Re: Where is AM Antenna (loren)
Post by ragingfish »
There is no separate outboard AM antenna. It's either part of the roof mast or (more likely) it's a ferrite rod inside the radio itself.Your installer is a doofus.
2009 PONTIAC G8
It's just a defroster on the back glass, no antenna. It is true that tinting *can* have some of an impact on reception for in-glass antennas, however that only affects cars that actually have in glass antennas, the Vibe does not. Tinting the glass in this car will have absolutely no impact on radio reception. Go for the more expensive tint, the itty bitty metallic particles won't hurt a thing. Don't cheap out, that stuff is crap. I've had Llumar with the metallic stuff in it for the last two cars, it's great stuff!
loren
Post by loren »
OK, sounds like I can use the better quality tint and not worry about it. Thanks for the input.
