Pre-Cataytic Converter
Petrucci914
Post by Petrucci914 »
Hey,I'm thinking about replacing my Pre-Cat and just eliminating the second one. I shouldn't get a CEL with that, right? One O2 sensor is in the header and the other is after the Pre-Cat so it should be fine, correct?
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
northvibe
Post by northvibe »
i think bluecrush did something similar.... of course there should be some other people that did some custom exhaust that will post up though!
BlueCrush
Re: Pre-Cataytic Converter (Petrucci914)
Post by BlueCrush »
I hollowed out my precat, which is built into the AWD header. I then replaced my second oem cat with a Magnaflow high flow cat. I kept getting the P0420 CEL code until I installed the Camcon and roughly tuned the A/F.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
manicdan
Post by manicdan »
what kind of changes would i see on my 05 GT if i were to get a better cat?
Petrucci914
Re: (manicdan)
Less Meowing, and more power, better gas mileage, etc.
drunkenmaxx
Post by drunkenmaxx »
actually i've seen tests where a high flow cat only added about 1hp over stock
Petrucci914
Re: (drunkenmaxx)
A horse is a horse. You'd probably see a better result with the fuel mileage. My Vibe was one of the first sets made and I'm guessing the Cat was never replaced under that TSB. So I kinda wanna get it taken care of.
tribalman
Post by tribalman »
is it possible to pull out the dual cat we have and just put in a single stage cat? would there be any benefit? sometimes if i'm driving for more than 45 minutes around the car is really warm and sometimes has an egg/fart smell.
None. Vibe is gone.
Petrucci914
Re: Pre-Cataytic Converter (tribalman)
If you're under 80k miles then bring it in under the TSB and they'll replace your ECU and catalytic converters for free.
