Hey,I'm thinking about replacing my Pre-Cat and just eliminating the second one. I shouldn't get a CEL with that, right? One O2 sensor is in the header and the other is after the Pre-Cat so it should be fine, correct?
I hollowed out my precat, which is built into the AWD header. I then replaced my second oem cat with a Magnaflow high flow cat. I kept getting the P0420 CEL code until I installed the Camcon and roughly tuned the A/F.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
A horse is a horse. You'd probably see a better result with the fuel mileage. My Vibe was one of the first sets made and I'm guessing the Cat was never replaced under that TSB. So I kinda wanna get it taken care of.
is it possible to pull out the dual cat we have and just put in a single stage cat? would there be any benefit? sometimes if i'm driving for more than 45 minutes around the car is really warm and sometimes has an egg/fart smell.
