Removing (tiny) rust spots from paint chips?
scoot
Post by scoot »
On my Vibe's hood there are a number of paint chips, which seems to be a fairly common problem. Some of them have began to show a little rust, which is something that I need to fix before I cover them with touch-up paint. Of course though is the problem that these paint chips are so tiny (~1-2mm in diameter) that they may be rather hard to fix.What would be the best way to remove the rust from these areas? I don't know if sandpaper would work well because these are tiny spots. If anyone has any suggestions as to how they would do/did this it would be greatly appreciated. Thanks!
2006_Salsa
Re: Removing (tiny) rust spots from paint chips? (scoot)
Post by 2006_Salsa »
Dremel Tool with a small wire wheel/brush
keithvibe
Post by keithvibe »
Sublimewind
Post by Sublimewind »
I tried finding it, but i couldn't. 3M used to make a pen type thing that had a fiberglass tip that you used to clean the chip area and then the other end had a rust converting applicator that you put on and then painted over... I looked for like 10min and couldn't find it though...
psiu
Post by psiu »
I got some of the rust converter from paintscratch.com, I plan on trying it pretty soon, if it works well I will try to mention it on here. I need to do it quick before summer ends anyway, I am in the same boat with my 2003 Vibe.
KNINE
Re: Removing (psiu)
Post by KNINE »
I've heard of people using an engraver, because the tip is so fine it gets the rust out without disturbing the paint around it.
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
Whelan
Re: Removing (K-NINE)
Post by Whelan »
+1 on the Naval Jelly
2012 GLI Autobahn 6MT
scoot
Post by scoot »
I guess I'll try the Naval Jelly. Does it have the ability to damage the surrounding paint at all? or is that something I don't need to worry about?Thanks for all the advice!
keithvibe
Re: (scoot)
Post by keithvibe »
I have used it directly on the paint, with out any problems in the past.WHAT i would suggest you try is this, spray or dab the jelly on to a Q-tip and apply it that way. In about 2 mins, wipe the excess away with a clean soft towel, then, wash it with water and all the rust should be gone. If not dry the area again and repeat. The less time left on the paint the better, to be on the safe side, but like I said before. I have never had a problem. After the rust is removed. Besure to dry the area very well and cover the chips up with new paint right away, or the next day when you come out the rust will be back again.
