I want to order some black rims with a chrome lip, but I just went to a website that says the 2006 vibe's rims are 17's. The tires on my car are 205 55 16.Does anyone know what I need to order? Thanks
Either rim size would work as long as the rubber on the rim is sized in acordingly so that the over all diameter stays the same. On base Vibes 16" is stock the GT's are a 17".
17's were an upgrade available on the GT...my GT came with 16's standard. The base Vibe is steelies with caps standard and upgrade to 16" aluminum...Joker, just make sure the bolt pattern is 5x100 and the tire is either 225/45/R17 or 215/55/R16 - I'm not as sure on the 16" standard, but check in the forum for tires and wheels and one of the stickied topics is a tire size calculator...match it to 225/45/R17
hey joker, what they said.i'm actually running 235 45 17s on my vibe, and the speed recorded on my gps is still spot on with the speedo.good luck on the purchase. i know you'll post pics when you put on the new shoes!!!!
de-badged o4 vibe
o2 triumph speed four
