Key Fob?
phreon
Key Fob?
Post by phreon »
I purchased my '04 Vibe about a month ago and couldn't be happier. The key fob battery was dead, so I replaced it. All the functions worked, but now I can't get the lift hatch to pop. I know I popped it with the remote before, but it doesn't seem to work anymore. The hatch opens using the dash button and the door locks operate from the remote just fine.I'm supposed to hold the "Hatch" button until it pops (about 2 seconds), right? Any ideas?Thanks,Phreon
GrayFox
Re: Key Fob? (phreon)
Post by GrayFox »
mine is a '05 but I just push mine once (no holding) and it opens...I'm not really sure what to suggest other than maybe trying a different battery or going back to the dealer (assuming it's a pontiac dealer that you bought it from) and seeing if you can get a new fob since you kinda just purchased the car
ragingfish
Post by ragingfish »
Quote, originally posted by phreon »I purchased my '04 Vibe about a month ago and couldn't be happier. The key fob battery was dead, so I replaced it. All the functions worked, but now I can't get the lift hatch to pop. I know I popped it with the remote before, but it doesn't seem to work anymore. The hatch opens using the dash button and the door locks operate from the remote just fine.I'm supposed to hold the "Hatch" button until it pops (about 2 seconds), right? Any ideas?Well, if you mean the glass, yes, you hold it. By the time i traded in my vibe, i had to hold it a good 3-4 seconds before it would go.If you mean the door itself, that does not pop, but it does unlock with the other doors.Thanks,Phreon
2009 PONTIAC G8
Whelan
Re: Key Fob? (ragingfish)
Post by Whelan »
could have somehow glitched the programming when you put the new battery in. Like a safety reset mode. Take it to the dealer to have them reprogram it. They dont charge around here at least.
2012 GLI Autobahn 6MT
joenobodyx
Post by joenobodyx »
Are all of your doors unlocked? On my Matrix, I'm 99% sure that you have to unlock all doors first by pressing unlock twice within 5 seconds on the fob, then you will be able to get the rear glass to open using that function on the remote--I believe using the trick you mentioned. At least that seems to be the case on mine...and if that is the case, the Vibe should be exactly the same.
Burn
Re: Key Fob? (nbkoontz)
Post by Burn »
For my 03 vibe, I have to hold the button for 2-3 sec to open the hatch window. It does'nt matter if the doors are locked or not. Opening this window does'nt affect the other doors.I would try to reprogram it.
Burn
Post by Burn »
Is it possible to lock the doors if they are open?I was able to do that with my 02 protege5 but not with my 03 Vibe...
ragingfish
Re: (Burn)
Quote, originally posted by Burn »Is it possible to lock the doors if they are open?not with the remote
2009 PONTIAC G8
NewNeptune
Re: (ragingfish)
Post by NewNeptune »
Quote, originally posted by ragingfish »not with the remoteI do that all the time. I'll get out and hit the lock button on the fob with my driver's door still open and it locks. Or I'll get the last bag of groceries out of the hatch and hit the lock button on the fob. Works every time.
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
Vibr8tr
Re: (NewNeptune)
Post by Vibr8tr »
Quote, originally posted by NewNeptune »I do that all the time. I'll get out and hit the lock button on the fob with my driver's door still open and it locks. Or I'll get the last bag of groceries out of the hatch and hit the lock button on the fob. Works every time.Same here, it just won't flash or lock the open door on mine until it closes.... but it will lock it once I close it.Also, try this http://forums.genvibe.com/zerothread?id=1437It is a way to reprogram it to your Vibe.... Maybe it just needs a "reminder" lol. Never hurts to try. Did you only get one FOB? I got two with mine.... but I think one was bought aftermarket kinda thing.
MSN: jjbova@hotmail.com - Yahoo: jjbova - Myspace: http://www.myspace.com/jjbovaSee My Vibe at Cardomain.com
4X4CHICHI
Re: (NewNeptune)
Post by 4X4CHICHI »
not on '04's
2004 FUSION ORANGE VIBE GT200 Watt CD & XM radio, Tinted windows17" Black Casino'sSilverstars Head and Fog, Injen C.A.I.http://www.cardomain.com/memberpage/453424
phreon
Problem Solved!
Post by phreon »
I reset the remote per the instructions given in the link in this thread and now the Hatch button on my remote works. My neighbor thinks I'm odd given the door closing performance, but the problem is solved.Thanks!Phreon
