Looking to buy 03 Vibe
justin0469
Post by justin0469 »
So I possibly buying an 03 Vibe AWD auto w/ 77k miles. Anything that Vibes has problems with I should look for?
justin0469
Re: Looking to buy 03 Vibe (justin0469)
This wasn't intended to be a "wanted" ad, it was intended to find out what I should be careful of when going to test drive one... If someone could move it back since a Mod moved it here.
ArcsVibe
Post by ArcsVibe »
Moved to the lounge
Genvibe Global Moderator
MOTM September 06 & July 09
VOTM April 06
Matrix XR 2010 (5-09-2014)
justin0469
Re: Looking to buy 03 Vibe (ArcsVibe)
thanks
I would have the AWD components checked out with a mechanic prior to buying it... There haven't been any widespread reliability issues thus far, however a few here have had some noises coming from the rear end and ended up with differential problems back there. VERY costly, a couple grand to replace the differential, IIRC. Make sure the previous owner has been changing the fluid in the rear differential, not doing so is one good way to kill it pretty quick.Otherwise, just make sure the tranny shifts smooth and that the engine doesn't make a lot of racket. It should have had a coolant flush at 30,000 and a valve clearance inspection/adjustment at 60,000 but few ever do that service. Aside from that, there were a few odds and ends such as windows that bind/snap/pop when rolling up and down, water leaks, crappy stock CD players, etc.
justin0469
It is from a Pontiac dealership. It is not certified since it has over 60k miles, but still went through their typical inspection process. It has navigation too. I test drove it and all seems good, though I think if I get it, I will be buying an extended warranty.
Anrosphynx
Post by Anrosphynx »
what are they asking for it?
justin0469
Re: (Anrosphynx)
asking 9988
CCD
Post by CCD »
Wow! I just paid 10900 for an 03 2wd with everything except Nav. with 40k miles on it.Sounds like a pretty good deal if it in the clean condition mine was in.
2003 base
justin0469
Re: (CCD)
Yeah, I don't see a single scratch or stain on it. But it has double the miles yours has almost. Edmunds blue book is $11,XXX for the Vibe I am looking at.
Anrosphynx
not a bad deal at all. especially with the factory navi. Those are pretty rare.
