Factory Alarm
DougVibeGT
Factory Alarm
Post by DougVibeGT »
Has anyone added the Toyota Matrix alarm to a 2006 Vibe GT? I found the Corolla/Matrix instructions online but I'm not sure if all the wiring is the same in a Vibe.
DougVibeGT
Re: Factory Alarm (DougVibeGT)
Anyone? When I was looking at a Vibe the Pontiac dealer thought they could put one in, but after the purchase they said it wasn't possible. I have a GT loaded.
BlueCrush
Post by BlueCrush »
Not sure on the wiring. But I would think it would be the same as the '06 Matrix XRS. Someone should be able to help you out. You may want to also ask about this on http://www.matrixowners as well.Welcome to GenVibe! (fellow Minnesotan)Join us for a Meet in Feb: http://forums.genvibe.com/zerothread?id=26712
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Jahntassa
Post by Jahntassa »
The factory alarm is not a 'slap in' alarm system. It requires things that probably aren't there if it wasn't pre wired for it, such as the wiring for the glass break sensor. I think you need a different multifunction module as well.It would be much cheaper and much less of a headache to get something aftermarket.
silvrhawk7
Re: (Jahntassa)
Post by silvrhawk7 »
Quote, originally posted by Jahntassa »The factory alarm is not a 'slap in' alarm system. It requires things that probably aren't there if it wasn't pre wired for it, such as the wiring for the glass break sensor. I think you need a different multifunction module as well.It would be much cheaper and much less of a headache to get something aftermarket.When i bought my car in Detroit, I asked the dealer about the factory alarm system, and I quote what they told me.... "It would be easier (and cheaper) to purchase an aftermarket system versus installing the factory system."
In Memory, taken too early in a rear end collision
Sunrise: June 2006, Sunset: Jan 2015 :cry:
Miles 129,000
2006 Silver Mono, Base 4-Speed auto.
In Memory of Pontiac Motor Division 1926-2010
In Memory of the Pontiac Vibe 2002-2009
DougVibeGT
Re: (silvrhawk7)
Thanks everyone for your advice. I'll look for an aftermarket alarm.
