Is there a fuel filter that needs to be changed?
whitevibe04
Post by whitevibe04 »
Does the Vibe have a fuel filter that need to changed?
Re: Is there a fuel filter that needs to be changed? (whitevibe04)
Yes and no. There is a filter, but it is in the fuel tank itself. Not the easiest thing to replace compared to the older cars that just had a filter in the line somewhere. So therefore, it's not a routine maintenance item... It's only changed when you experience issues with the flow of fuel, doesn't ever require changing under normal circumstances.
ragingfish
Post by ragingfish »
I traded in my vibe at just under 70k and never did anything with the fuel system...Though with the longevity of the vibes on this board, 70k is pitiful.
2009 PONTIAC G8
micbarric
Post by micbarric »
Here is a pic of the Vibe-Matrix-Corolla fuel filter to the right of the oil filter:It would take a lot of dirt before a filter that big would need to be replaced!
2005 Frosty
