Doors not locking
DUGsVibe
Doors not locking
Post by DUGsVibe »
When using the key chain transmitter, not all of my doors are unlocking/locking. It does this with both transmitters. Anybody else have this problem? I'm wondering if the car battery is going bad.DUG
2003 VibeK&N air filter - No other mods.HOOAH!
ragingfish
Post by ragingfish »
You are hitting the unlock button twice?
2009 PONTIAC G8
VforVIBE
Re: Doors not locking (DUGsVibe)
Post by VforVIBE »
When unlocking your doors, hitting the unlock button once with unlock the driver's door, hitting it twice in a row will open all the doors and hatch. But all the doors should lock when you hit the lock button.BTW Welcome to GenVibe!
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
ragingfish
and BTW, if only one or two doors are un/locking, it's not an indicator of the health of your car battery. If there is a legitimate malfunction, it's something with your RKE system and you need to have the dealer investigate further...
2009 PONTIAC G8
DUGsVibe
Re: (ragingfish)
Post by DUGsVibe »
What is thr RKE system?
Kari
Re: (DUGsVibe)
Post by Kari »
The remote keyless entry system
GenVibe Global Moderator
Atomb
Post by Atomb »
if NONE are locking..check to make sure your rear hatch is closed fully/properly. if it's not properly latched, the doors won't lock when using the key fob.
VforVIBE
Re: (Atomb)
Post by VforVIBE »
Quote, originally posted by Atomb »if NONE are locking..check to make sure your rear hatch is closed fully/properly. if it's not properly latched, the doors won't lock when using the key fob.and the lights won't blink
ragingfish
Re: (VforVIBE)
Quote, originally posted by VforVIBE »and the lights won't blinkand you'll become constipated...OOPS! Wrong thought. I just had a drunken-moment!
2009 PONTIAC G8
DUGsVibe
Re: (ragingfish)
Post by DUGsVibe »
I HATE when that happens. It seems like only 2 doors won't unlock, but it varies which doors. I also noticed the doors unlocking and locking all by themselves. At least the lights were flashing on and off all by themselves.
Jahntassa
Post by Jahntassa »
Yes, you have a problem. Go see your dealer.
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
is it the OEM remote???i wonder if there is an aftermarket alarm or remote start issue here.
mcgusto82
Re: (silverawd26)
Post by mcgusto82 »
The doors re-lock after 30 secs if no door is opned after being un-locked byt the key-less. 05 and up auto vibes lock after going into gear. just adding some info. maybe it can help.
DUGsVibe
Re: (silverawd26)
Post by DUGsVibe »
The doors were unlocking while nobody was in the car. My wife thinks the kids might have been stepping on her coat with the keys in the pocket. I'm not sure if that was the case. She says it's always the rear driver's side and front passenger side locks not locking OR unlocking. Using the key doesn't make any difference either. It's a 2003 Vibe that I bought new in '02 and still has the original battery. The winters here in the Northwest get really cold and I think it is probably time for a new battery anyway. I had a problem a while back with a Pontiac Grand Am where the door locks were locking all by themselves and the Tachometer kept redlining for no reason. The problem after spending a lot of money at the Pontiac dealership was a dead cell in the battery.
ragingfish
That's an oddity. It could be a malfunction in the module that controls door locks. Also could be a problem within those two doors. Sounds like a dealer visit for sure.
2009 PONTIAC G8
DUGsVibe
Re: (ragingfish)
Post by DUGsVibe »
I think I'm putting a new battery in this weekend anyway. If that doesn't fix it, I'll take it to the dealer and let everybody know what the problem was.SGT DUG
Atomb
Post by Atomb »
franken-vibe....it's alive! IT"S ALIVE!...or a ghost maybe?
