High-pitched humming noise over 60mph
Dilweed
Post by Dilweed »
Do any of you hear the higher-pitched hum of the engine above 60mph?? It's very noticeable to me from 58-60 or so; it's as if it kicks into annoying-hum mode at that point. Do you think this is normal or based on the positioning of the engine? Thanks!
2005 (Base/Automatic) - Silver, Gray; 17" alloys; ABS; Power Everything inside;* Rockford Fosgate Punch's in door panels; Disappointing gas mileage so far...
Digger
Re: High-pitched humming noise over 60mph (Dilweed)
Post by Digger »
I have no sounds like that.
BlueCrush
Post by BlueCrush »
Could it be from the front tires and it just sounds like its coming from the engine? Is it the same on all road surfaces?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Dilweed
Re: High-pitched humming noise over 60mph (BlueCrush)
Post by Dilweed »
Quote, originally posted by BlueCrush »Could it be from the front tires and it just sounds like its coming from the engine? Is it the same on all road surfaces?It just sounds like the engine hitting a high note above 60 mph. I'm not sure about the tires. It IS from the front end... and I'm not sure about other surfaces because I don't go that speed on dirt roads or concrete, etc. It happens whenever I hit above that speed. Hmmmm...
BlueCrush
Post by BlueCrush »
Might want to check the belt and tensioner pulley as well.
My Fleet:
Dilweed
Post by Dilweed »
Quote, originally posted by BlueCrush »Might want to check the belt and tensioner pulley as well.So, I should bring it in while it's still under warranty?
BlueCrush
Post by BlueCrush »
I would have them take a look at it. But, some dealers charge for diagnostics if they find nothing wrong. Maybe one of the service techs could go for a ride along with you and then determine if it needs more diagnosis or if they tell you it is normal. Did this just start happening? or has it always done it?
My Fleet:
Dilweed
Post by Dilweed »
Quote, originally posted by BlueCrush »I would have them take a look at it. But, some dealers charge for diagnostics if they find nothing wrong. Maybe one of the service techs could go for a ride along with you and then determine if it needs more diagnosis or if they tell you it is normal. Did this just start happening? or has it always done it?It's always done it. GOt it in late July. Had 6,700 miles then, too. Seems awfully new to already start humming/whining.... Grrrr....
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
i dont think those tires were supposed to be there in the first place.17's on a base vibe... was that an option?there is more to the tire story i think.even at 6700 miles if not rotated and are "cheaper" tires they can "feather" or "cup"- that will give a noise like thatmore noticable on the front cause thats where all the weight is.
NewNeptune
Post by NewNeptune »
17" tires are an option on the base Vibe. Dilweed, do yours look like this?http://www.pontiac.com/images/...g.jpg
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
Dilweed
Re: (NewNeptune)
Post by Dilweed »
Quote, originally posted by NewNeptune »17" tires are an option on the base Vibe. Dilweed, do yours look like this?http://www.pontiac.com/images/...g.jpgYep! And they're crappy factory tires, too. Can't have those on there this winter, that's for sure. I started a tire change thread, too, and I'm trying to figure out what I should do without breaking the bank over this.
ke4yyd
Post by ke4yyd »
Mine does the same thing, not sure what speeds it is dominant. I usually drive with the radio on which masks the sound. It is definitly a power train derived noise as it stops when I let off the gas to coast. Tire noise would continue.
Dilweed
Re: High-pitched humming noise over 60mph (ke4yyd)
Post by Dilweed »
Yeah, mine stops when I let off the gas, too. That's why I thought it was an engine, related thing. Gets up there around 58-60 and above.
