Can I turn off my headlights
mikey44
Post by mikey44 »
I have encountered a problem involving the headlights on the Vibe. I work on a Naval Base and on the few times I drive the Vibe (wifes car) to work, (6 am, dark) naturally, I have to go thru the security gate to get on base. One of the requirements, which has been for years, is to turn off your headlights as you come to the gate to enable the security guard to be able to see the base sticker on the windshield without being blinded. Well, every time I've taken the Vibe to work, I get a mild (removed)-chewing from the guard because I don't/can't turn off the headlights. Any way around this? I don't use the headlight stalk, just let them automatically come on when I pull out of my garage.
esjones
Re: Can I turn off my headlights (mikey44)
Post by esjones »
Mikey - You have run afoul of the dreaded and oft-discussed Daytime Running Lights/Automatic Headlight "feature" of the Vibe. Use the forum search feature to find other discussions on this topic, including how to disable these dubious features. I think someone said that a dealer would disable the DRL function if a suitable reason (like base rules) were given. - Earl
- Earl Earl Jones, Sales and MarketingHorizon Systems LLChttp://www.horizonsystems.com/ Skype ID: esjonesMy Vibe: '03 Base, 5-speed, ABS, Alum. Wheels, Power Pkg, DVD Nav., Security, Neptune/Graphite
NovaResource
Post by NovaResource »
We've only discussed this about a thousand times. The SEARCH function (upper right of page) found these threads (out of dozens) that should answer your questions:http://forums.genvibe.com/zerothread?id ... s.htmOther info:http://www.lightsout.org/disable.html
DopeVibeGT
Post by DopeVibeGT »
Welcome new member. As Scott said, please try the SEARCH button at the top of the page before you post a new thread. Thanks.
Pictures of my ride!!'03 Vibe GTMy AED GA!Work in progress
bellwilliam
Post by bellwilliam »
now I am confused !!! isn't all GM the same as the Vibe? is so, why would the guard give you an (removed) chewing? is there something I am missing here?
Bellwilliam2003 S/C VibeTrim : Base, Abyss , AutoOptions: Moon & Tunes, Power Upgrades: Supercharger, Split Second A/F controller, 225/45-17, My other cars are PTE Miata, 13 Tesla S, 13 Volt, 06 997
cohocarl
Re: Can I turn off my headlights (bellwilliam)
Post by cohocarl »
quote:now I am confused !!! isn't all GM the same as the Vibe?No. All G.M. vehicles I have driven will allow you to turn off the D.R.L.'s by pulling up 1 click on the e-brake, but not on the Vibe. Not far enough to engage the brake, but far enough to activate the switch.I think the D.R.L.'s on the Toyota based Vibe is a P.I.A.
