Air pump
CivicDestoyer
Air pump
Post by CivicDestoyer »
Has anyone taken out the air pump?
Digger
Re: Air pump (CivicDestoyer)
Post by Digger »
what airpump
ragingfish
Post by ragingfish »
i suspect he means the smog pump
2009 PONTIAC G8
CivicDestoyer
Re: (ragingfish)
Yep. I mean the smog pump. Is there a real purpose for this other than emissions?
CAN-AWD-VIBE
Re: (CivicDestoyer)
Post by CAN-AWD-VIBE »
why does it need to go away, I like it where it is, not on my garage floor.I think it allows fuel vapor to be re-introduced into the fuel supply.Something like that... I do know if there is a leak there you will get a CEL. CAN-AWD-VIBE
Re:
Back in the day, people would pull the belt off their smog pump because as we all know, anything that runs off the crank will rob power from the engine..BUT... These are electric, I think. If I'm remembering correctly. I don't see how disconnecting it will give you any benefit, only will increase emissions. I can't say for sure though. There was a horsepower decrease that came along with the GT the same year that the smog pump appeared, but horsepower decreased every year after 2003 so who's to say the smog pump did it.
Digger
Post by Digger »
What does this pump look like? Do all the vibes have one?
Re: (Digger)
From what I've read around here, I was under the assumption that it is just GT models after 04 or so but I could be mistaken. Not sure where it is or what it looks like though.
