which sig do you like better
meathead333
Post by meathead333 »
the white one, or the gray one?
My myspace.com profile My 73' Bronco Cardomain page
BlueCrush
Re: which sig do you like better (meathead333)
Post by BlueCrush »
Gray one!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
drunkenmaxx
Post by drunkenmaxx »
the white one is better, even though more plain, you can read the text.in the grey one, the blue text looks washed out.-edit-to make the grey one better, put a stroke around the outside of the blue text, or make a box behind it with a lighter color and just fade the box by reducting that layer's opacity.if you don't have a copy of that with the layers still intact, use the magic wand tool to select a piece of the blue text and then go to >select >similar and it will let you grab all the blue. then create a new layer via cut and you can do what you want.
rebbierae
Re: which sig do you like better (drunkenmaxx)
Post by rebbierae »
Grey.
NascarXprt
Post by NascarXprt »
Quote, originally posted by drunkenmaxx »the white one is better, even though more plain, you can read the text.in the grey one, the blue text looks washed out.-edit-to make the grey one better, put a stroke around the outside of the blue text, or make a box behind it with a lighter color and just fade the box by reducting that layer's opacity.if you don't have a copy of that with the layers still intact, use the magic wand tool to select a piece of the blue text and then go to >select >similar and it will let you grab all the blue. then create a new layer via cut and you can do what you want. +1 on helping the blue stand out alittle more, but the grey one is better IMO.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
meathead333
i like the grey one a little bit better too. i was pissed though because i forgot to save the psd file. so now i cant really go in and edit it that much
rebbierae
Post by rebbierae »
You meathead.Man, I crack myself up...
IDT_Designer
Post by IDT_Designer »
In my professional opinion, the aliasing on the dark one is better, the drop shadow makes the vibe look flat. the lower case sanserif font works better, and the gray BG has more contrast. I would suggest a gradiated background, keep the blue text, and add sharper shadow (cars are photographed outside generally). But If I had to pick I would say the light one overall. But just needs polished up more. I would be glad to cut out your vibe and restore your PSD for you if you want, send me the photos.
Get Creative or Go Home!
meathead333
i changed the font color to orange... i like it better now.thanks joatmon!
Merzbow
Post by Merzbow »
number two..white one.
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
SuperSpeedWagon
Re: (meathead333)
Post by SuperSpeedWagon »
the one that is on it right now right now is pretty sweet keep it like that
2010 vibe gt
northvibe
Post by northvibe »
yeah i like the darker one.
NascarXprt
i like the new sig great color combos Meathead!
