play a audio dvd?
21Rouge
play a audio dvd?
Post by 21Rouge »
I will soon come into possession of some DVDs which contain hundreds of mp3 audio files. I know nothing about stereo 'stuff' so I am wondering is there car stereo equipment that will play such a DVD? The current OEM '05 Vibe CD player wont play mp3 files. Is it possible to convert these mp3s to wma files and burn them to a CD?Any other sugggestions?
Jahntassa
Post by Jahntassa »
There are probably some higher-end multimedia systems that will play DVD's of mp3's, but not that many.There is no need to conver to WMA before burning to a CD. Just use CD burning software to burn 'Music CDs'.
21Rouge
Re: (Jahntassa)
Post by 21Rouge »
Quote, originally posted by Jahntassa »There are probably some higher-end multimedia systems that will play DVD's of mp3's, but not that many.So the advantage of using a DVD is that it can hold many more mp3 files than a CD.Quote, originally posted by Jahntassa »There is no need to conver to WMA before burning to a CD. Just use CD burning software to burn 'Music CDs'.The reason I suggested converting to WMA is that the 05 Vibe's OEM CD doesnt play mp3s.
Jahntassa
Post by Jahntassa »
The Vibe's OEM CD player doesn't play WMA either. There's no reason to convert from one unplayable format to another when you can go straight from MP3 to normal CD Audio.And yes, the advantage of using a DVD in this particular case is just that it holds more. The term 'Audio DVD' is a bit misleading though, because for a period of time, there were home systems that would play DVD Audio which was standard audio at a higher bitrate than normal CDs.
northvibe
Post by northvibe »
Yeah you would need a pc with burning software like Nero burning rom to pull the mp3's you wanted then burn to standard cd-r in a audio cd format. I have seen some aftermarket head units that play dvd-r mp3 music discs.
Re: (Jahntassa)
Quote, originally posted by Jahntassa »The term 'Audio DVD' is a bit misleading though, because for a period of time, there were home systems that would play DVD Audio which was standard audio at a higher bitrate than normal CDs.Is that different than DVD-A's? I loves my DVD-A discs I have even with having a crummy system at home, *drool!* If I could have something like that in the car, man! It sounds so fricken good compared to the regular CD copies of the same albums!
21Rouge
Re: (northvibe)
Post by 21Rouge »
Quote, originally posted by northvibe »Yeah you would need a pc with burning software like Nero burning rom to pull the mp3's you wanted then burn to standard cd-r in a audio cd format. I have seen some aftermarket head units that play dvd-r mp3 music discs. So just to confim: It is easy to take mp3 files and burn them to a standard cd-r which will play on our 05 OEM cd player in the Vibe?
BuzzDog
Re: (21Rouge)
Post by BuzzDog »
If you've got the right software on your PC, it's relatively easy. Most of the PCs I've bought in the past few years have an application like those produced by RoxioFirst, you put the disc into the PC and "rip" the tracks (songs) to your hard drive. Then you put a blank CD in and use the program to drag and drop your tracks into a window, in the order you want the songs to play. Finally, you click on the "burn" button (or whatever it's called in your program) and wait for the computer to do its thing.By the way, if your program has a checkbox marked "Finalize CD," I'd highly recommend checking it. I seem to have less problems playing the CD in older players when I do that.
BuzzDogLocated in beautiful Northwest Arkansas2005 VibeFrosty • Moons and Tunes
21Rouge
Re: (BuzzDog)
Post by 21Rouge »
Quote, originally posted by BuzzDog »First, you put the disc into the PC and "rip" the tracks (songs) to your hard drive. Then you put a blank CD in and use the program to drag and drop your tracks into a window, in the order you want the songs to play. Finally, you click on the "burn" button (or whatever it's called in your program) and wait for the computer to do its thing.I have done exactly that with wma files but I thought it would be a problem doing the same with mp3 files...the resulting cdr will play in the basic OEM 05 Vibe CD player?
mcgusto82
Re: (21Rouge)
Post by mcgusto82 »
The term you are looking for is "GIGAmp3". Typically it's just a larger storage disc. theyh are not that expensive.ehere's an example of a DVD unit.http://cgi.ebay.com/JVC-KD-DV4...wItem
BuzzDog
Re: (21Rouge)
Post by BuzzDog »
Quote, originally posted by 21Rouge »I have done exactly that with wma files but I thought it would be a problem doing the same with mp3 files...the resulting cdr will play in the basic OEM 05 Vibe CD player?I do it all the time. If you actually burn it to a CD as described - by setting up an audio CD project and not simply copying the files to a CD - the software on your computer should convert it to the correct format as it burns the CD. You might just want to give it a shot...all you stand to lose is a blank CD.
21Rouge
Re: (BuzzDog)
Post by 21Rouge »
Quote, originally posted by BuzzDog »I do it all the time. If you actually burn it to a CD as described - by setting up an audio CD project and not simply copying the files to a CD - the software on your computer should convert it to the correct format as it burns the CD. You might just want to give it a shot...all you stand to lose is a blank CD.Yup. Thanks for the encouragement. It worked fine.
