What is this compartment in the rear cargo area for?
Salsa One
Post by Salsa One »
Thanks in advance.
2006 Pontiac Vibe1997 Pontiac Trans Am 2001 Chevrolet Silverado
Mrizzle05
Re: What is this compartment in the rear cargo area for? (Salsa One)
Post by Mrizzle05 »
well duh... storage!!! I use it to hold my jumper cables... and maybe lil things i dont want rolling around but not in the back seat.It also may be for the first aid kit that you can get through the dealer.
zionzr2
Post by zionzr2 »
driver side one holds my spare tire remote fill and pressure check valvethe passenger side holds a roll of papper towels
the1stacekiller
Re: (zionzr2)
Post by the1stacekiller »
I use it for paper towel & some cleaner.. my friend uses it for tire foam and cable ties if you are an audiophile you can hide a sub & amp in there
- 2004 Pontiac Vibe Base 2 Tone Grey Goodness -
tcam
Re: (the1stacekiller)
Post by tcam »
I don't use it for anything, but I know that Bluecrush uses one compartment to hold a small fire extinguisher which I thought was pretty cool.
Mrizzle05
Re: (tcam)
Post by Mrizzle05 »
Quote, originally posted by tcam » but I know that Bluecrush uses one compartment to hold a small fire extinguisher which I thought was pretty cool.BC a true street racer!!!
binary
Post by binary »
I bought a "jug-o-bungie-cords" from autozone for $20, it's a great place to store them instead of under the trunk lid.I always have a heavy load - loaded before I grabbed the bungies out... so now I don't have to unload to get them.As for the passenger compartment - that's just an access port for your brake/turn lights. Not technically a storage compartment - but it's your car... you won't hurt it by storing something there.Just remember the air exhaust vents are directly below each door. So don't store bulky things like towels or blankets there - you'll block the vents. This will cause over pressure when you open the windows at high speed. (your ears will pop) And it'll keep your heat/ac from working as well.
Salsa One
Post by Salsa One »
Okay. Thanks. I put all my crap here.
mcgusto82
Re: (Salsa One)
Post by mcgusto82 »
i do believe that it's an access to the rear lights' harness, and bulbs...
Re: (Salsa One)
They're technically there to allow for convenient changing of tail light bulbs. Yeah, I just missed mcgusto's post.
Image Image
ZubenElGenubi
Post by ZubenElGenubi »
Yup...access to the taillights...but I keep my cargo nets in there when not in use.Oh, and Welcome to GenVibe by the way.
Salsa One
Post by Salsa One »
Thanks for the welcome. I have a lot to learn about the Vibe.
