It seems that when I put the car in reverse and back up, come to a complete stop, put it in 1st and go to pull away that I can hear a noise coming from under the car. Sounds kind of like a hollow clunk. Anyone else get this?
2006 Vibe (base) - Platinum Silver, 5 spd, ABS, Power Package, Infinity Speakers, Dynomax muffler, Cosmo SR intake - SOLD
Try backing up and going forward a few times to see if it keeps doing it each time after your initial start/reverse/1st run. That will tell you if it is the ABS or not. Let us know your findings after doing this.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Glad I found this post!! my 2005 Vibe was making the same strange clunking noise. I tested it out and found out it was only after going in reverse and then moving forward between first and second gear shifting. I notified the dealer and they checked out the brakes and did some minor adjustments and lubrication which seems to have fixed the issue!Thanks again folks.
