Quote, originally posted by coldmm803 »what is that big hose in the attached pic, will it effect hookin up an intake?An aftermarket intake replaces the entire stock assembly, which consists of that tube (which leads to the throttle body), the airbox to the right (contains the stock filter element) and the tube that leads from the box back into the engine bay to "inhale" air.
That would be the new smog line for the '05+ Base Vibes. You cannot use just any intake. It will need to have a port to accomodate that hose. Right now only Cosmo makes a CAI that will work for that set-up. There is a new person on here (shanemade) that is using a Weapon-r Secret Intake (Short Ram) with out any CEL's at this time. There may be other Short Rams that will work with the '05+. If you do decide to go with the Cosmo you'd better oder it fast as they are in short supply and high demand. Good luck!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
thanks blue, i saw shanemades' first post in the lounge which brought up the discussion of the weapon r intake, i was the first one to responed to it, i just wasnt sure what it was cause i didnt see it in his pics unless i missed it. so if i get a weapon r will i have to take off the engine cover to do something with that hose or will it just hang down where it is. psycho just so we're on the same page, i realize that the main hose from the air box to the throttle body gets removed.
[QUOTE=Psychobroker]That would be the new smog line for the '05+ Base Vibes. You cannot use just any intake. It will need to have a port to accomodate that hose. Right now only Cosmo makes a CAI that will work for that set-up. There is a new person on here (shanemade) that is using a Weapon-r Secret Intake (Short Ram) with out any CEL's at this time. There may be other Short Rams that will work with the '05+. If you do decide to go with the Cosmo you'd better oder it fast as they are in short supply and high demand. Good luck!QUOTE](removed), I guess I thought he was talking about the intake tube itself
