Helix Power Tower Plus
4azdmunky
Re: (Petrucci914)
Post by 4azdmunky »
that is what I tried, Pontiac must have changed the bolt patern and the throttle body size with the 05 DBW. This thing won tmatch up bolt patern regardless of what i do....damn!
Digger
Post by Digger »
It worked great on mime. ???? By the way My MPG are back up to normal and the power is still better than before.
Petrucci914
Re: (Digger)
Post by Petrucci914 »
Either you're just missing something with the installation or they sent you the wrong spacer. Does it match the picture of blue crushes? I can get the number off my box if you need it.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
binary
Post by binary »
Digger's AWD doesn't have DBW - it still uses the original throttle body.I'm worried that they changed the bolt pattern with our DBW's... I know BC had some photos of his install (page 1 of this thread - http://forums.genvibe.com/zero...age=1 ) it may be worth comparing and see if that's what you got.If it is, this accessory may not fit.What I think is kind of funny about this mod is that it may generate horsepower - but not like anyone thinks it does, or even how it's advertised. Think of how a golf ball's dimples help it fly farther by generating turbulence around it, or how a pickup truck's tailgate up creates a pocket of air behind the cab - giving it better aerodynamics.What this may be doing, in theory, is generating enough turbulance to keep the main stream of the air away from the heated throttlebody - and also giving a faster, smoother tunnel of air going into the throttlebody.The only time you're probably going to see this advantage is when the throttle plate is at 90 degrees (WOT) where it can't cause turbulance.
4azdmunky
Re:
Post by 4azdmunky »
Petrucci914 -> The part I have is part 97185. Is that what you have?Bianary -> I read through all of the posts here and on matrixowners about this mod. I researched both sides of the argument (it works, it doest work) even researched the science on this product. It was kind of amusing because the exact same arguments are posted in the S10 forums I also frequent. According to the dynamics of airflow and pressure, this thing should not work on my truck (or for that matter on our vibes). So, I bought it for the whistle sound (I know, sounds like a tool decision), installed it, and it surprised the hell out of me how well the thing worked. I left the battery hooked up, so the PCM didn’t reset, so no other variable changed but the truck had such an improvement that the mud tires break loose every easily now on hard top, and you get pushed back into the seat quite hard when it didn’t do it before.Now I know that personal feeling is not true tangible fact, and personal observation is open to interpretation. So, long story short, it should not have any impact in my truck, it does, so even though it should not have an impact on our vibes, I bet it does as well. In the QA/IT/Programming world A+B=C is not always true. In reality A+B= Not C, and A+B=Other Result. or :A+B= It worksA+B= It doesn’t workA+B= It works and we don’t know why (ie, any Microsoft OS)I agree with you, I think this works but no one understands why.If its all placebo,...then bring on the sugar pills!
4azdmunky
Re: (binary)
Post by 4azdmunky »
yea, what i have looks exactly like that.
Petrucci914
Re: (4azdmunky)
That's what the picture on blue crushes shows, as far as numbers. I dunno. You have the same vehicle that he does, right? Those engines were a bit different, 126HP instead of 130? Did the intake manifold change or somethin?
BlueCrush
Re: (Petrucci914)
Post by BlueCrush »
It may be that the DBW have a larger throttle body. I just saw on NewCelica.org that that some are saying the DBW Celica TB's are larger than the DBC Celica TB's. Not sure if they have confirmed it though, nor are they saying if the bolt pattern size has changed.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
dug
Post by dug »
Sorry, I had to resurrect this old thread:Has anyone tried drilling a hole in this TBI spacer for water injection? I know URD makes one for Toyota's 3.4L, IIRC, but I don't think anyone's done WI through a throttle body spacer. It'd be a clean install if it could be done!http://www.urdusa.com/product_...801ea
BlueCrush
Re: (dug)
Post by BlueCrush »
No, but that would be an ideal location for it on the Helix.
My Fleet:
northvibe
Post by northvibe »
I just dropped off my car a couple days ago for a warranty fix on a couple parts and they said nothing about my throttle body spacer OR my strut tower bar! good new so far.
Lancer
Re: (northvibe)
Post by Lancer »
They probly didn't even know it's not suposed to be there. The one's that I've seen don't have any experiance working on Vibes.
hubcaphead
Re: Helix Power Tower Plus (BlueCrush)
Post by hubcaphead »
I wanted to take the time out to thank you for posting a link to our website. I ant to offer you a $10.00 off coupon for part number spe-97185 which is the picture that is shown. The code is SSGEN0506Please use this whenever and as many people that want to use it can. Thanks again for the post!!http://www.hubcapsplus.com
lexicon
Doesnt look like they make Helix Power Tower Plusone for the 05' Vibe-I emailed
Post by lexicon »
I emailed the manufacturer and no response.Does anyone know different?
2005 VibeAutomaticStockNon AWD125 hp model
northvibe
Post by northvibe »
I want to see a DBW so i can see the diff... I would think its the bolts. thats whats making it not fit the 2zz.
scherry2
Re: (northvibe)
Post by scherry2 »
just put some gas in since the install of northvibes used helix power tower. I go about 31 to 32 MPG in town driving rough est.(40 MPH or less) now to try it out on the Interstate. i also noticed a little more pep in the low RPM range. It isn't hurting so i'm happy with my purchase.
lexicon
How do you define Pep?
Post by lexicon »
Just a question,How can you physically tell youve got a 1-3hp increase in a low hp engine?Is the pep basically extra noise, since its not dynoed and wasnt taken to the drag races for timed trials, what are you actually measuring?I am not trying to challenge you on this, but , if someone had installed the unit on your car, without your knowing, would you have been able to tell the difference.To me, more efficiency "should" translate to better gas mileage. So, if your gas mileage consistently increases over a period of say 3 or more tanks of gas, then , this is a measurable change .For example. I also have a >200,000 mile Corolla. I religiously got 30 mpg no better, sometimes 29mpg.After doing Seafoam in the engine intake, I immediately saw 33 mpg and 31.5 mpg. Now , Months later, I am seeing at least 31.5 mpg.So, here, I saw a measurable increase.Thanks
scherry2
Re: How do you define Pep? (lexicon)
Post by scherry2 »
placebo effect?
Digger
Re: How do you define Pep? (scherry2)
Post by Digger »
I saw a big diferance in the pep of my 05 AWD. It shifts better. Does not bog down on slight inclines. The MPG dropped at first then got better. I can tell a big differance in mine. I did put a short ram on at the same time though.
lexicon
How to troubleshoot or determine how a change affects the final result
Post by lexicon »
Part of basic troubleshooting is to only change one thing at a time.If you change multiple things simultaneously, you dont know where the change in the system came from.So, in this case, we dont know if the perceived improvement is from the stack or spacer.What is your mileage change (based over several tankfulls)?
Digger
Re: How to troubleshoot or determine how a change affects the final result (lexicon)
Post by Digger »
I went up 4 MPG 25-26 to 29-30
BlueCrush
Re: How to troubleshoot or determine how a change affects the final result (Digger)
Post by BlueCrush »
After I installed mine, I experienced more torque in the low and mid rpm range. I also experienced a 2-3 mpg increase.
My Fleet:
lexicon
What will it take to get the manufacturer to produce a Helix Plus for 2005 and 2006 years
Post by lexicon »
I sent an email to the mfr. and no response.Does anyone know an internal contact at Helix?
vibe Freak
Re: What will it take to get the manufacturer to produce a Helix Plus for 2 ... (lexicon)
Post by vibe Freak »
All I can say is this thing works great. I have a Base auto vibe with the spacer and intake, and the car really came to life after the spacer. Pulleys are next then wheels. But it is a no brain-er get it you will not be disappointed. Thanks to Blue crush for telling me about this great mod. Dominic
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
LUVROK
Post by LUVROK »
Does anyone offer a 2ZZ model?What's the bolt issue related to the 2ZZ? Does the throttle body have a different bolt pattern? I would be happy with a blank with no holes drilled so I can drill or mill my own.
2005 GT, Neptune, Injen CAI, Magnaflow Catback Exhaust, Eibach Sportline Springs, Progress Rear Swaybar, DC Sports Strut Tower Bar, Tow package
yeye
Post by yeye »
Did this make any difference in noise for those running this with intake or any other mods. Wondering if it makes the car louder or not?
northvibe
Post by northvibe »
theres no difference in noise when i used it.
BlueCrush
Re: (northvibe)
Post by BlueCrush »
Mine made slight BOV type/light whistle sound when I accelerate hard and let off the gas. Other than that, no noises.
My Fleet:
Mrizzle05
Re: (BlueCrush)
Post by Mrizzle05 »
Quote, originally posted by BlueCrush »Mine made slight BOV type/light whistle sound when I accelerate hard and let off the gas. Other than that, no noises.LOVE that sound... all i gotta say
VforVIBE
Post by VforVIBE »
Quote, originally posted by BlueCrush »The install was fairly easy. It took about 1/2 hour. I had to modify my CAI by cutting off about an inch.The spacer is 1" thick and is aluminum.Quote, originally posted by Digger »I saw a big diferance in the pep of my 05 AWD. It shifts better. Does not bog down on slight inclines. The MPG dropped at first then got better. I can tell a big differance in mine. I did put a short ram on at the same time though. do you think a short ram would need to be cut down?Edit: they don't make it for the 05 & 06 do they?
“I live my life free of compromise, and step into the shadows without complaint or regret.”
Viva la Pontiac! 2009 Jet Black GT
GrayFox
Re: Helix Power Tower Plus (VforVIBE)
Post by GrayFox »
BC's vibe is an 05 but he has cable throttle....
BlueCrush
Re: Helix Power Tower Plus (ANO_Vibe)
Post by BlueCrush »
There is one out for the '05-'07 DBW. If you have more than 1" of space between your filter and your fusebox then you should be fine with no cutting. If not, you will need to trim some off.
My Fleet:
VforVIBE
Post by VforVIBE »
Quote, originally posted by ANO_Vibe »BC's vibe is an 05 but he has cable throttle....AWD Quote, originally posted by BlueCrush »There is one out for the '05-'07 DBW. If you have more than 1" of space between your filter and your fusebox then you should be fine with no cutting. If not, you will need to trim some off.Awesome, thanks man... I was looking over your Poor mans mod list and I was like nope, can't do that or that... but I can do this, yay!
MAVibe
Post by MAVibe »
Any idea who has the best price for this spacer(05-07)? I actually haven't found the one for the '04-'06 Corolla 1ZFFE DBW #97188 available anywhere.....
HISTORY:2006, debadged, Cosmo Racing SR, Megan Racing strut bar, Progress swaybar, custom VVT-I body decals, GrafxWerx engine cover overlay, front-end bra, WeatherTech visors, S2000 antenna, f&r mudflaps, roof spoiler, AND MODA R9's w/ 225/40/18 Yokohama Avid's....
kevera
Re: Helix Power Tower Plus (MAVibe)
Post by kevera »
MAVibe
Re: Helix Power Tower Plus (kevera)
Post by MAVibe »
That's for the 2002- 2004 models....part #97185.... I have the '06 1zf....
kevera
Post by kevera »
IZF..huh,you mean 1zz.I don't think it matters.I think it will work.
BlueCrush
Post by BlueCrush »
Quote, originally posted by MAVibe »Any idea who has the best price for this spacer(05-07)? I actually haven't found the one for the '04-'06 Corolla 1ZFFE DBW #97188 available anywhere.....Contact these guys to find out where you can get it: http://www.streetandperformanc...d.htm
My Fleet:
MAVibe
Post by MAVibe »
Thanks BC! That's exactly what I did this morning.....waiting for response.
kevera
Post by kevera »
Or ask KeithVibe which one he used,I think he has an 06 DBW.edit:Nevermind,he has an AWD.SorryThat's why I gave you the link,I thought he had DBW,my mistake.
ProtonXX
Post by ProtonXX »
I have a scangauge 2 & I can try this out to get some numbers on it.
keithvibe
Post by keithvibe »
LOL... Sorry I do have AWD... This is why I didn't chime in on the topic. But since I have installed the spacer I would pay the money just for the sweet POV sound it makes on the highway with out overdrive engaged. I noticed slight gains in the low end of the RPM range.
MAVibe
Re: Helix Power Tower Plus (keithvibe)
Post by MAVibe »
I heard back from Street&Performance---the spacers are not available and there is no release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....
BlueCrush
Post by BlueCrush »
Quote, originally posted by MAVibe »I heard back from Street&Performance---the spacers are not available and there is no release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....What? Bummer! Well, then why do they have it listed for the 1zz DBW celica?
My Fleet:
Vivid_Art
Post by Vivid_Art »
So is this spacer really worth the money? you guys think it would do much for a base Vibe w/ a Cai and Header installed?
ProtonXX
Re: (Vivid_Art)
Post by ProtonXX »
Dunno yet but I did the Coolant bypass & seafoam today & my scan gauge was throwing out a retarded 100mpg at 45mph & 2gph idle. Old numbers was 40ish & 3GPH idle. It obviously needs re calibrating lol.The temps reading for the engine water & SR stayed the same 200F & 100F
ProtonXX
Re: (ProtonXX)
Post by ProtonXX »
Just did a road trip to cali & back. Got 30 MPG coming back which never ever happened before. Coolant Bypass MOD for the win :D
manicdan
Re: (ProtonXX)
Post by manicdan »
any updates on a 2zz version yet?
His_and_Her_Vibes
Re: (manicdan)
Post by His_and_Her_Vibes »
...Bump... (my first - hope I did it right!) Any release date for the Throttle Body Spacer for the late model 1.8's w/ DBW (2005-2007).....???? I've ordered a TBS for my Wife's '04 Vibe. Hopefully it will improve gas mileage. It has a K&N drop-in filter, but I will likely install either an AEM, INGEN or Cosmo CAI very soon. (as soon as I decide which one!)
J.Mack __0 >;(_/_) "Grab Life by the Handlebars!"2004 VIBE (Hers) - Fusion Orange (BevoVibe) - May she R.I.P2007 VIBE (His) - Moonstone (MakoVibe)
kevera
Re: (His_and_Her_Vibes)
Post by kevera »
Bump for what
