an ECU question
joholste
an ECU question
Post by joholste »
alright so i have searched and i still couldn't find anything on this subject. what i want to do is tune an 05 PCM to adjust the air-fuel ratio, i would like to make it run a little more lean... i know some would advise against this but as my car right now is running a little rich i don't think it will hurt it. and stock these cars run a little rich anyways. What will i need to retune my ECU to the Specs that i want, i would like to do it so that i can actually adjust the air/fuel on my laptop and have it send it to the ECU ?
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
Mase
Re: an ECU question (joholste)
Post by Mase »
As far as I know, you can't reprogram the toyota ECU. You can get one of several available piggyback modules though such as the Camcon, E-Manage, Unichip, etc.Bluecrush posted an extensive amount of info about them a while ago.http://forums.genvibe.com/zerothread?id=20250
goodvibe
Post by goodvibe »
With your add-ons, you're probably not running rich at WOT and at part throttle they run lean anyway.
djb383
Post by djb383 »
Check the inside of your exhaust tip - is it black or sooty? One of my '05 Vibes has 13K miles and the inside of the exhaust tip looks almost sterile, it is so clean. These puppies run very lean, after all they pass '07 CARB emissions.
joholste
Post by joholste »
the inside of my exhaust tip is very black. and i cleaned it right before coming up to nebraska, and i've only driven about 500 miles since then, and what about a Power Force Commander?? does anyone have one of these??
djb383
Re: (joholste)
Post by djb383 »
Kinda sounds like it is running rich. Might want to check spark plugs. Porcelin tip s/b tannish color. Don't know anything about the PFC. Good luck.
satur9
Re: (djb383)
Post by satur9 »
the pfc works great. but theres not a vibe/matrix specific harness so youll need a custom one.also you lose obd2 capabilities so no emissions testing.
joholste
Re: (satur9)
Post by joholste »
can i assume that you have one?? and how do i lose the OBD II?? does the PFC completely replace the ECU??
