Motor Mounts going bad
jcarvibegt
Post by jcarvibegt »
Anybody have any problems with this yet? Apparently mine are starting to go bad. I'm at 51,500 miles. It's the first thing that i'm gonna have to get fixed that isn't just maintenence. Luckily I bought an extended warranty with $0 deductible.
http://www.cardomain.com/id/jcarvibegt03 Pontiac Vibe GT AbyssSony Xplod MP3 Head unitCrunch Drive Series SE-200 AmpRockford Fosgate P2 Punch 12" Sub WooferXenon headlights and Fog LightsGrafxwerks overlay
ragingfish
Re: Motor Mounts going bad (jcarvibegt)
Post by ragingfish »
I think the noise my car makes when it's in drive, but I have my foot on the brake, may be motor mount related. They replaced the exhaust manifold AND the serpentine belt, but the problem is still there. It's either the tranny or the mounts IMHO.
2009 PONTIAC G8
scherry2
Post by scherry2 »
other than your engine lifting up how can you tell if your motor mounts are going bad?
jake75
Re: Motor Mounts going bad (scherry2)
Post by jake75 »
I am sure your warranty covers motor mounts but I bought a 1987 Plymouth Voyager and the extended warranty. One of the motor mounts failed and it was not among the listed parts covered. Cost me $140. I was streamed.
Mase
Post by Mase »
If your mounts really are going bad, you may be able to get away with spending $30 on some polyeurothene inserts. That'll reinforce what's left of the stock rubber mount, plus lock your engine down tighter to the frame. And it's better than paying $$$ for new OEM mounts.Nevermind...just read you have the $0 deductable ext warranty...
scherry2
Post by scherry2 »
Quote, originally posted by scherry2 »other than your engine lifting up how can you tell if your motor mounts are going bad? I guess no one knows.
goodvibe
Post by goodvibe »
They tear and allow excessive movement. You can take the front one out in 5 min. and look at it Or just reach in and feel it with your finger. I suppose a mirror and light would work also. The rear can go bad if the front was reinforced without the back. jcarvibegt, how do you know that yours are bad? I don't think they'll get replaced under warranty if they're just getting soft.
jcarvibegt
Re: Motor Mounts going bad (goodvibe)
My mechanic was the one who mentioned to me that the mounts were going bad when i asked him to check out the car. BTW the warranty did cover them and they were replaced on 10/21. Man! What a difference. It got rid of most of the notchy feeling in the ****fter. No more missing gears or grinding into shifts. I wish i would have done this months ago. I think it even feels better than when the car was new. Apparently the engine shifting too out of place, wrecks havoc on the tranny. Makes me think that this could have been the problem with the tranny from the begining.
